FS: Buschur 35r Cast Manifold Kit and more!
1 Post
Ok guys my cast manifold set is FS. It is still on the car and I will remove here with in a few days (proly x-mas day).
My car is going to Buschurs at the end of January/ Feburary, for a full build and I need to get this stuff sold.
Complete 35r cast manifold kit, with a Buschur polished heat sheild. The CHRA has MAYBE 1k on it. The compressor housing is a Tial/ HTA cover, all that is needed is the HTA wheel, for a full HTA kit. There is ZERO surge with this housing. I will include the feed line, return fittngs. 44mm Tial wastegate, with dump tube. And the 02 housing is already been drilled and welded for a front o2 sensor.
Also I have PTE 880 injectors.
Buschur MAF Pipe w/ silicone coupler and clamps to turbo
Buschur Air Filter
Forge 1g Flanged BOV... works great with BR UICP that is flanged for a 1g.
255 single Walbro fuel pump aswell.
Looking for $3100 for everything. plus shipping.
Also included in the price I will include the correct scalling factors needed to make the injectors work with your stock ECM, and latancy voltage #'s as well.
If you have a IX, I will send you my own pump (93) map, and or C16 map... which should get you REALLY close for an awsome tune.
I WILL NOT PART OUT... DONT ASK
Pics and dyno sheets can be found at www.myspace.com/vwjeff. of just search for threads I have started.
Here is a pic of the compressor housing that is on the car now with a few others....
Buschur Air Filter
