KW Variant3 $1849! Swift Spring & Swaybar $725! Stoptech Rotors+Pads&Lines F&R $599!
EVO SUSPENSION UPGRADES!
KW VARIANT 3 COILOVERS
The KW Variant 3 Coilovers are one of the very best high performance coilovers for the money. Featuring a piggy-back reservoir as well as independent 14-way compression and rebound adjustment, this feature rich coilover can be fine tuned as a race-winning coilover while maintaining civility and comfort on the street.
Independently adjustable damping technology -rebound and compression damping
inox-line stainless steel technology at no extra charge
Individual height adjustment
German TUEV-tested adjustment parameters
Infinitely adjustable rebound damping
14- level adjustable compression damping
Unique, independently functioning damping power adjustment
Spring rate of 9/6 (custom rates available)
$1849 Shipped!!
Apex Exv N1 Damper
-Complete kit with upper pillow mount
-32 dampering/rebound adjustability
-Upper CNC aluminum top hat w/pillow ball mounts
-Front camber adjustable
-Double height adjustment
-44mm piston
-Excellent ride quality
-Spring Rate 8/6kgmm
$1199 Shipped!!
Swift Sport Springs + Swift Swaybar Set
- Progressive Spring 3.2-4.8 kg/mm Front, 3.7-5.7 kg/mm Rear
- 1.4" lower Front, 0.8" lower Rear
- uses H5S.TW material
- Manufactured with cold winding coiling technology
- Lighter in weight, fewer coils, yet consistent linear spring rate
- Superior Durability, does not sag or fatigue over time.
Swaybars
- 118% Stiffer Front
- 120% Stiffer Rear
$725 Shipped!
Whiteline Rear Swaybar w/ Bushings
-New Bushings
-Choice of 22mm, 24mm Adjustable
$149 Shipped!!
CLICK HERE FOR SUSPENSION SPECIALS -- UPDATED DAILY
EVO BRAKE PACKAGES!!
StopTech Rotors, Hawk Pads, & Gruppe-S Lines Front and Rear!
-Stoptech Slotted Rotors Front and Rear
-Hawk HPS Pads Front and Rear
-Great Replacement to your stock set up
NEW Gruppe-S SS Brakelines
-SUS 304 Stainless Steel
-Teflon Tubing Covered
-Full Set, all four corners!
$599.00 SHIPPED!
Upgrade to Hawk Plus Pads Only $30.00 More!
PERFORMANCE FRICTION 2 Piece Rotors and Brake Pads!
-Floating 2pc Design
-Serious reduction in rotating mass means more power
-Greater temperature reduction means better braking, especially on the track
-Improve wheel bearing life
-Performance Friction Special Street Race Pad Part #: PF1001.10
$649 Shipped!! (Front Pair)
Add SS Lines for $75!!
We have a ton of other parts check out our site.
CLICK HERE FOR BRAKE SPECIALS -- UPDATED DAILY
If you would like to place an order please give us a call
Thanks!
Gruppe-S Sales
$1849 Shipped!!
Apex Exv N1 Damper
-44mm piston
$1199 Shipped!!
Swaybars
- 120% Stiffer Rear
$725 Shipped!
-New Bushings
$149 Shipped!!
$599.00 SHIPPED!
Thanks!
Gruppe-S Sales
