The once a year ZEITRONIX wideband sale thread you have been waiting for in 2007!
#93
The Christmas holiday is upon us and its that time of year to offer something special up to evom members in appreciation of another year as part of the evom family.
This year, ONLY FOR A LIMITED TIME we have decided to make owning the best wideband available for your Evo, a little bit easier.
A wideband fully compatible with EVOSCAN datalogging inputs!!!
We have a few new packages below that are numbered. Please review the packages and PM us if you have any questions. When you are ready to make your selection, please send paypal payment to sales @ttp-engineering.com with the package number indicated in the notes section. If paying by credit card, please email us the number of the package you have selected along with your phone number to take your order and card number over the phone.
Again, any questions can be sent via PM, AIM or sales@ ttp-engineering.com.
Make this Christmas special for your Evo!
__________________________________________________ ___________
Package #ZR1R- Send us a PM!
Zeitronix ZT2 wideband PLUS ALL NEW ZR-1 GAUGE IN RED LED that displays AFR. Also for use with laptop for viewing, logging up to 9 hours of datalogging of RPM, TPS, AFR, Lambda, and Aux input 0-5v straight out of the box.
Includes the ZR-1 Gauge plus Zt-2 Wideband Air/Fuel Ratio Meter, Wideband Oxygen Sensor, Sensor Harness, Signal Harness, PC Serial Cable, Datalogging Software, Installation Instructions, 2 pin EGT connector to retrofit your EGT probe and ZR-1 Gauge with peak and hold feature. High contrast LEDs visible even in a direct sunlight. Made in the USA.
Package #ZR1B- Send us a PM!
Zeitronix ZT2 wideband PLUS ALL NEW ZR-1 GAUGE IN BLUE LED that displays AFR. Also for use with laptop for viewing, logging up to 9 hours of datalogging of RPM, TPS, AFR, Lambda, and Aux input 0-5v straight out of the box.
Package #ZR2BL- Send us a PM!
Zeitronix ZT2 wideband PLUS ALL NEW ZR-2 GAUGE IN BLUE LED Multi Gauge Combo which can display AFR, BOOST, EGT or LAMBDA and is switchable! Also for use with laptop for viewing, logging up to 9 hours of datalogging of RPM, TPS, AFR, Lambda, and Aux input 0-5v straight out of the box. Includes the ZR-2 Multi Gauge and Zt-2 Wideband Air/Fuel Ratio Meter, Wideband Oxygen Sensor, Sensor Harness, Signal Harness, PC Serial Cable, Datalogging Software, Installation Instructions, 2 pin EGT connector to retrofit your EGT probe and ZR-1 Gauge with peak and hold feature. High contrast LEDs visible even in a direct sunlight. Made in the USA.
Package #1- Send us a PM!
Zeitronix ZT2 wideband only for use with laptop for viewing, logging up to 9 hours of datalogging of RPM, TPS, AFR, Lambda, and Aux input 0-5v straight out of the box.
Includes the Zt-2 Wideband Air/Fuel Ratio Meter, Wideband Oxygen Sensor, Sensor Harness, Signal Harness, Datalogging Software, Installation Instructions and 2 pin EGT connector to retrofit your EGT probe.
Package #2- Send us a PM!
Zeitronix ZT2 wideband PLUS BLACK ANODIZED LCD SCREEN that displays, TPS, BOOST, AFR, Aux 0-5v input. Also for use with laptop for viewing, logging up to 9 hours of datalogging of RPM, TPS, AFR, Lambda, and Aux input 0-5v straight out of the box.
Package #3- Send us a PM!
Zeitronix ZT2 wideband PLUS BLACK ANODIZED LCD SCREEN that displays, TPS, BOOST, AFR, Aux 0-5v input. ALSO INCLUDES 3.5BAR (35.5psi) medical grade precision MAP sensor for boost logging! Also for use with laptop for viewing, logging up to 9 hours of datalogging of BOOST, RPM, TPS, AFR, Lambda, and Aux input 0-5v straight out of the box.
Package #4- Send us a PM!
Zeitronix ZT2 wideband PLUS BLACK ANODIZED LCD SCREEN that displays, TPS, BOOST, AFR, Aux 0-5v input. ALSO INCLUDES 3.5BAR (35.5psi) medical grade precision MAP sensor for boost logging. Also includes low mass, high response K thermocouple EGT sensor for lightning quick EGT logging and viewing on the LCD display. Also for use with laptop for viewing, logging up to 9 hours of datalogging of BOOST, EGT, RPM, TPS, AFR, Lambda, and Aux input 0-5v straight out of the box.
Package #5- Send us a PM!
Zeitronix ZT2 wideband PLUS BLACK ANODIZED LCD SCREEN that displays, TPS, BOOST, AFR, Aux 0-5v input. ALSO INCLUDES 3.5BAR (35.5psi) medical grade precision MAP sensor for boost logging. Also includes low mass, high response K thermocouple EGT sensor for lightning quick EGT logging and viewing on the LCD display. Also includes ZAVT- Zeitronix AUDIO-VISUAL alarm and safeguard trigger. FULLY PROGRAMMABLE warning LED and alarm that you can bas on simple EGT, AFR, BOOST, TPS, RPM and/or COMPLEX warning such as (IF AFR> 12.00 AND BOOST >22PSI AND TPS> 75%, THEN TRIGGER WARNING). This feature works especially well with TTP-Engineering's meth injection systems to insure a trouble free tune. Also for use with laptop for viewing, logging up to 9 hours of datalogging of BOOST, EGT, RPM, TPS, AFR, Lambda, and Aux input 0-5v straight out of the box.
Pick your package and send us a PM!
#97
#105
Great deals still available POST-SALE!
