HOW TO: $7.32 Boost Leak Detector
1. Run to your handy hardware store (Grainger, Home Depot, Lowes), etc. and pick up a 3" to 2" rubber reducer from the plumbing section.
2. Go get a 2" PVC pipe plug/end
3. Go get a tire valve stem, can be found at Auto Zone, Murrays, Sears etc.(Home Depot may not have it, mine didn't)
4. Drill a hole in the end of the PVC cap, then stick the valve stem up from the inside out.
5. Stick the PVC cap w/valve stem in the 2" side of the rubber reducer, tighten hose clamp.
6. Remove your intake hose and attach the 3" side to the turbo, tighten hose clamp
7. I regulated my air compressor to about 3psi so I don't put too much air in the system. Now you can charge your system with the same attachment the you use to fill your tires with
I only needed 3psi to find my leak that is on the throttle body
Pics are right before I changed the PVC cap from the green hose to the tire valve stem. Use your imagination
The problem I have with those stupid rubber reducers is that they say 2" or 3" or whatever, and when I measure it, it's always at least half an inch wider. Example I purchased a 2" to 3" and the 3" side was 3.5" wtf. It took me way too long to piece together the proper rubber/pvc pieces. Stupid rubber couplers. Anyways I'm just venting, good write-up, you can also add a gauge to the tester so you don't have to rely on your compressor for a reading. Oh you may also be able to just get a rubber end cap and use that instead of reducer/pvc end cap.
Edit: The inlet on our turbos is really 3"? I would have thought it was smaller
I think the outside diameter of the turbo is a little bigger than 3", but the coupler slips over the outlet with a little umph
mplspilot
63
Jun 18, 2014 11:03 PM
