Vroomevo's - Aquamist HFS-5, JDM style
pump/tank/pump JDM style - assembled and ready for installation
more install pics
at edwin's home
vroomevo and esevo discussing tuning strategies
more install pics
at edwin's home
I have had report of a HSV problem and subsequently failed due to heat flux from the front under track works. Is it possible to shield the HSV and flow sensor or reposition it in the wiper motor compartment. (preferably shielded from direct rain spray.
Here is one location a WRC car put the HSV and lived to tell the tale.
Abner - Seems like you got this down to a science. This is what your 5th install already?
Richard - was the heat failure on an Evo? I would not expect it to get that hot at the back of the engine compartment.
thanks Abner for posting pictures!
no leak!!! hahaha...
now i am turning up boost slowly, so far so good. minimal knock.
until i reach my target boost, i will hold on timing and fuel maps.
we(zzombae and I) will give you good result after tunning soon Abner.
hope you visit tucson sometime soon.
Chong
Chong
Richard - with regard to failure of the HSV from heat, how hot is too hot?
After driving around yesterday I popped my hood and felt the HSV, it was warm to the touch but not hot at all. I could have easily closed my hand around it without it being hot.
Granted, this was after normal driving around and not racing.
There isn't much point using 180C winding for the coil. EPDM seal will be damaged and all water will be pushed out of the valve at ~8.5bar + 125psi pump pressure.
