Aftermarket & Factory Parts for Sale!
Do not respond to this thread. See my new for sale thread here- https://www.evolutionm.net/forums/sa...ml#post6804441
NEW PARTS!!! NEW PRICES!!!!
I have a buncha parts I need to sell because they are taking up too much room. Parts are for an Evo 8.
***JUST ADDED NEW PARTS***I will get pix as soon as I can
AFTERMARKET
*Fluidampener Aluminum one! $- practcally brand new!
*Buschur Racing catch can- $- practically brand new!
*Precision injectors- #8246 17113814- IDK what CC's-
*AEM pressure sensor and O2 sensor-
*05 STI short block EJ25, Eagle rods, unknow pistons. 1 cyl wall cracked. $
*2 good Eagle rods, 2 spun bearing rod.
*Tubular manifold used.
*1 set of none turbo lancer lowering springs. $50
*1 sets of 00-05 eclipse lowering springs. $50
NEW Forge EVO 8 wastegate
Perrin intake tube.
Used Aluminum underdriven crank pulley $15
Universal fuel pressure regulator $15
FACTORY
*1 set of front calipers for EVO. peeling like norm, not too bad. $250 for 1 set.
*1 91-93 3000GT VR4 short block. Stock. Sounded like spun bearing, non were loose when removed. $
*1 06 6speed trany. 4th gear is done, trans is disassembled but complete. $600 OBO?
*guts of transfer case. ring gears/shafts etc $200? OBO
*Stock Evo intercooler. $150
*electronic throttle body for new mitsubishi. Make offer
wastegate $35
radiator. Has 1 nic in it that leaks. can be repaird. $
Boost gauge. $15
Volt gauge $15
Left hand door handle. White but can be painted. $25
intercooler sprayer with good pump $
O2 housings 2 of them. Does 1 includes the o2 sensor.
diverter valve $15
2 sets intake & exhaust camshafts $
Head Bare has small chips in cyl's 3&4 but still good STILL GOOD HEAD!
-Had David Buschur look at detailed pix. He believes it can still be built into a STG 3 head, If you wanted to have it built. It can not be used as a core on one though. $
Evo 8 Factory rear struts and springs. $250
3 good pistons and rods best $
1 Ebay special T3 manifold. Ghetto reinforced and high temp painted black. $
1 good MR front strut. $75
1 stock rear sway bar with stock mounts $50
1 stock cam gear cover $20
1 stock battery tray $obo
6 SPEED
2.4L BARE HEAD
DIFF HOUSINGS AND RING GEAR- VISCIOUS NOT INCLUDED
STOCK INTERCOOLER
USED MANIFOLD- MEGAN RACING POSSIBLY?
2 GOOD EAGLE RODS
2 SPUN BEARING RODS
FIRST SET OF FRONT CALIPERS WITH PINS
NONE TURBO LANCER LOWERING SPRINGS- BLUE SET- ECLIPSE SPRINGS ARE RED
ELECTRONIC THROTTLE BODY
SOLD PARTS
Evo 8 Turbocharger. Less than 500 miles. $200
*GSC S2's- new ones! I will have mid next week- $400 SOLD
Evo 8 power steering pump. Bought of member for a friend. 10k miles on it. sold
1 good used crankshaft 4g63 best offer sold
Brand new in box Factory pressure plate and clutch disk. SOLD
http://i225.photobucket.com/albums/d...forsell012.jpg
Evo 8 20G TME with 10.5 hotside. sold
http://lancershop.com/customer/produ...&cat=17&page=1
http://i225.photobucket.com/albums/d...forsell056.jpg
http://i225.photobucket.com/albums/d...forsell057.jpg
http://i225.photobucket.com/albums/d...forsell055.jpg
Stainless O2 housing with gaskets. sold
http://i225.photobucket.com/albums/d...forsell050.jpg
K&N drop in filter sold
http://i225.photobucket.com/albums/d...forsell022.jpg
LC-1 widebank O2 sensor. sold
http://i225.photobucket.com/albums/d...forsell013.jpg
Megan downpipe with flex section. sold
http://i225.photobucket.com/albums/d...forsell009.jpg
Factory turbo oil return pipe. sold
http://i225.photobucket.com/albums/d...forsell051.jpg
Factory Evo 8 4g63 crankshaft. sold
http://i225.photobucket.com/albums/d...forsell037.jpg
Factory intake piping, intake boxes. Intercooler sold
http://i225.photobucket.com/albums/d...forsell034.jpg
http://i225.photobucket.com/albums/d...forsell026.jpg
http://i225.photobucket.com/albums/d...forsell036.jpg
TurboXS diverter valve sold
http://i225.photobucket.com/albums/d...forsell048.jpg
Factory Fuel rail sold
Maxford Stainless tubular manifold. no antilag ports. sold
http://i225.photobucket.com/albums/d...forsell052.jpg
http://i225.photobucket.com/albums/d...forsell054.jpg
http://i225.photobucket.com/albums/d...forsell053.jpg
Precision 780cc fuel injectors sold
http://i225.photobucket.com/albums/d...forsell018.jpg
Resonated cat delete pipe. sold
http://i225.photobucket.com/albums/d...forsell008.jpg
Factory wheel lock set. sold
http://i225.photobucket.com/albums/d...forsell019.jpg
Factory size aluminum crank pulley sold
http://i225.photobucket.com/albums/d...forsell015.jpg
GReddy Evo2 cat back exhaust sold
http://i225.photobucket.com/albums/d...forsell007.jpg
http://i225.photobucket.com/albums/d...forsell006.jpg
Factory exhaust. perfer pick up. make offer sold
http://i225.photobucket.com/albums/d...forsell035.jpg
http://i225.photobucket.com/albums/d...forsell032.jpg
http://i225.photobucket.com/albums/d...forsell033.jpg
2 Factory Evo 8 fuel pumps $30 both sold
http://i225.photobucket.com/albums/d...forsell014.jpg
Factory exhaust manifolds. 2 of them $60 each shipped sold
http://i225.photobucket.com/albums/d...forsell028.jpg
http://i225.photobucket.com/albums/d...forsell039.jpg
Factory Intake manifold bare $180 shipped sold
Factory springs and retainers $40 plus shipping sold
http://i225.photobucket.com/albums/d...forsell010.jpg
Pioneer 6x9 speakers New sold
http://i225.photobucket.com/albums/d...forsell066.jpg
***MAKE OFFERS- NEED TO MOVE PARTS FAST***
This is an old thread, but everything is still for sale. I need to clear out my space so make offers on everything. NEW PARTS!!! NEW PRICES!!!!
AFTERMARKET
Perrin intake tube.
FACTORY
wastegate $35
Boost gauge. $15
Volt gauge $15
diverter valve $15
6 SPEED
2.4L BARE HEAD
STOCK INTERCOOLER
2 GOOD EAGLE RODS
2 SPUN BEARING RODS
SOLD PARTS
No converter. Just the delete pipe.
The LC-1 Comes with the cables, weld in bung, sensor, the lil black controler box thing. I bought it off a member on here. I will find the link with more/better pix.
Here is the link to where I bought the LC-1. Everything attached to the O2 sensor in the pic (all the wires too) Did NOT get the LM pictured tho.
https://www.evolutionm.net/forums/sh...05#post4263805
