Milo's 18 quart Aquamist HFS-5 methanol/water injection system + pics of car
Old Sep 3, 2007, 03:10 PM
SlowCar's Avatar
All thats left is a good tune
Old Sep 3, 2007, 03:15 PM
xiaoni420's Avatar
Wow, look awesome guys! Good work!
Old Sep 3, 2007, 03:46 PM
fromWRXtoEVO's Avatar
Abner,
One more time I am impressed with your work however I think is overkilled. 18quarts? Cmon man, I am using a 1/2 gallon container and it last 3 gas tanks on my set up.
I heard that some people would like you to come back to Tucson to install some Aquamist kits. The Aquamist system is great and sophisticated but too fancy for me. The more sensors you put, the more connectors you put, the more switches you put the greater the chance of something going wrong.
Anyway, great job again Abner, it looks like you mastered the installation and "design" of those Aquamist systems.
pshhhh, when are you coming to Tucson?
Carlos
Old Sep 3, 2007, 03:52 PM
Duby's Avatar
where did you get the parts for a dual nozzle setup ?? and what sizes did you go with? maybe a website or phone number please. I'm trying to set up a dual nozzle for myself. Great setup- I love it
cheers
Old Sep 3, 2007, 03:58 PM
Evoryder's Avatar
THis the same car from before or another car with the 3 containers?
Old Sep 3, 2007, 04:04 PM
SlowCar's Avatar
Originally Posted by fromWRXtoEVO
Abner,
Carlos
In order to make lots of power safely, you got to inject a lot to raise the octane value / latent heat of vaporization - to keep knock away.
The beauty of the aquamist hfs-5 system is the simplicity! The injection follows injector duty cycle, perfect atomization/perfect AFR at all times. The only sensor is the flow sensor for the failsafe- when installed correctly, the system will take care of itself.
I'm thinking sometime in October...real busy at work.
Old Sep 3, 2007, 04:09 PM
max2evoix's Avatar
nice work man..keep it up..
Old Sep 3, 2007, 04:12 PM
APEX1's Avatar
Abs- I here you on this. My tuner said my car was not responding well with the 2 jets?? Said it was getting WAY too much meth. HE said 1 pull on the dyno- the tank went down 1/2 inch.
Old Sep 3, 2007, 04:13 PM
SlowCar's Avatar
cheers
http://www.aquamist.co.uk/sl/plist/frm-4-USD.html - dealers
this system runs the 2 biggest nozzles, 1.0mm and 0.9mm
you will need to add another nozzle is:
-either a "Y" or a "T"
-a jet adaptor
-a nozzle
AlohaEvo's Avatar
wow, thats a lot of meth...is he running two 1.0 nozzles?
edit
never mind see it above....
Old Sep 3, 2007, 04:14 PM
SlowCar's Avatar
same car from the Super Size It thread
Old Sep 3, 2007, 04:23 PM
SlowCar's Avatar
which jet did he keep?
i'll pm you
Old Sep 3, 2007, 06:03 PM
Abner,
Rewind about 2 years ago. Remember the issue you were having by injecting too much water on your prior Evo? When you put so much it actually handicap the ignition system to the point were you can actually loose power, in other words, the sparplugs are having real hard time doing there job .
Abner, remember that you had to go and get the HKS DLI II to fix your ignition issue..
Carlos
Old Sep 3, 2007, 06:08 PM
Bigpuna's Avatar
Very clean install ... HOT EVO
Old Sep 3, 2007, 06:13 PM
Registered User
johnny's Avatar
milo, thats an awesome setup you got there
Quick Reply: Milo's 18 quart Aquamist HFS-5 methanol/water injection system + pics of car
