Interior & exterior LED lights, HID kits on Sales Now!
We are now selling IIKDO HID Kits and IIKDO LED lights to our Evolutionm members at a great discount price.
T5 (1 LED)--> color avaliablity: super white only. (most use for instrument light)
$2.99 per pair, $1 shipping charge for any qty.
T15 (4 LED)--> color avaliablity: super white and Blue. (most use for side marker, daytime running light or lic. plate)
$3.99 per pair, $1 shipping charge for any qty.
T20 (9 LED) (single leg)--> color avaliablity: super white and red. (most use for directional signal, tail, back up or parking light)
$15.99 per pair for super white color, $9.99 per pair for red color. $2.5 shipping charge for any qty.
1156 (12 LED) (single leg)-> color avaliablity: super white, blue, yellow. (most use for directional signal, tail, back up or parking light)
$15.99 per pair for super white color, $9.99 per pair for yellow and blue. $2.5 shipping charge for any qty.
1157 (12 LED) (double leg)->color avaliablity: super white or red. (most use for stop light)
T10 (most use for map, dome, trunk light)
Size (in mm): 11 x 41 --> color avaliablity: super white, blue, yellow, green and red.
11 x 39 --> color avaliablity: super white and blue.
11 x 31 --> color avaliablity: super white and blue.
$17.99 per pair. $2.5 shipping charge for any qty.
Super bright 55W Halogen blubs.
Bulb types avaliable: H1, H3, H4(H/L), H7, H11, H13(H/L), 9004(H/L), 9005, 9006, 9007(H/L).
colors: super white and super yellow. H13 only come with super white.
$24.99 per pair for super white, add $3 for super yellow bulb. $3 shipping charge for any qty.
Any LED lights when use to flash (ex. direction signal) are recommended to replace the instock flasher to LED flasher.
$14.99 per each, $ 2 shipping charge for any qty.
Model: DX004
Model: DX010
4 LED spot lights that plug in to your car's cigarette plug. Each spot light comes with double side adhesive tape.
color avaliablity: super blue and 7 color LED.
$9.99 per each, $2 shipping charge for any qty.
NEW!
Model: DX016
10 LED light on 4 x 1.75 in panel with double side tape on the back. Waterproof panel which good for outside and inside installation.
$9.99 per each. $3 shipping charge for any qty.
IIKDO HID Kits:
IIKDO HID Kits are $219.99 shipped per kit.
IIKDO HID Bulb is $54.99 shipped per each.
IIKDO HID Ballast is $79.99 shipped per each.
Bulbs types:
H1, H3, H4/9003, H7, H11/H8, H13, 9004, 9005/H10, 9006, 9007 and D2C(D2S/D2R)
H13, 9004 and 9007 are low beam only, H4/9003 has HID for low beam and Halogen bulb for high beam.
Color temperature:
3000K=Super Yellow
4300K=OEM HID White
6000K=Extreme White
8000K=Ice Blue
10000K=Brilliant White
12000K=Violet Purple
Paypal to: theljnet@verizon.net
You can PM me or email me at theljnet@verizon.net, if you have any questions.
Thank You!
Model: DX004
Model: DX010
NEW!
Model: DX016
IIKDO HID Kits:
Bulbs types:
Color temperature:
3000K=Super Yellow
4300K=OEM HID White
6000K=Extreme White
8000K=Ice Blue
Thank You!
I don't think our evos have a map light. If you were meaning the interior lights which locate behind the rearview mirror, they are T15 bulbs and have 3 of them. For the dome lights, from sylvania, they are DE3175 which are T10 11 x 31 (mm).
As you can see from the picture, one right hand side is the stock dome light bulb(the light locates behind the rearview mirror), one the left hand side is our T15 LED light bulb, it is 100% plug N play. If the bulb does not come on, simply install it another way because + and - terminals do matter for LED bulb (it will not burn out the LED bulb, if you install on the opposite way).
I will try to confirm the type of the bulb for license plate , brake light, tail light, sidemarker, turn signal. But the best think is that take out the bulb which you want to upgrade to LED, and compare to our picture.
For the rear:
Trunk: T10 11 x 31 (mm), 1 bulb.
Lic. plate: T15, 2 bulbs.
Backup: T20 single filament (single leg), 2 bulbs for both side.
Stop: T20 double filament (double leg), 2 bulbs for both side.
High mount stop: T20 single filament (single leg), 1 bulb.
Tail: T15, 2 bulbs for both side.
Rear turn signal: T20 single filament (single leg), 2 bulbs for both side.
Interior:
dome light: T15, 3 bulbs.
Front:
Sidemarker: T15, 2 bulbs for both side.
Turn signal: T20 single filament (single leg), 2 bulbs for both side.
Parking: T15, 2 bulbs for both side.
Spec is from my 2005 Evolution VIII with SSL package.
Hope this information will be helpful!
