Latest FORGE EVOGREEN and stock IX turbo HIGH Boost actuators!
Forge Motorsports LATEST revised EVOGREEN and Evo IX / 20g LT 9-5 and 9-6 actuators in stock.
*NEW cast bracket, actuator arm, turnbuckle revision and weatherproof actuator arm boot. These are the best yet.
In from a long backorder, these are the best units yet!
Limited quantities, get your EVOGREEN equipped for maximum boost.
*Warning- this actuator coupled with a suitable blow off valve will allow the Evogreen to produce boost peaks in excess of 36-38psi as tested and datalogged on a 2006 Evo IX with stock MIVEC cams and TTP-Engineering methanol injection system.
The range of boost with the actuator is 20-38psi.
this will work on a stock turbo 9 with MBC or EBC right? and minum boost is 20psi? Will it hold boost longer? I would imagine so. Sorry for all the questions lol im just interested in getting one.
Just a few more left.
We will be using this unit to break the CBRE Evogreen record.
