FS: Gt35r Turbo only
SOLD!!!!!!!!!!!!!!
I have a Gt35r with about 10k miles on it. Highest boost It has seen is 28psi which netted me 540whp.
It does have the true garrett .82 a/r exhaust side which you can tell by the 4 bolt pattern. Its has a 02 housing welded to it and can be used and any stock placement downpipe.
It has the t04s 4in compressor housing cover with anti surge ports.
I want to get a bigger turbo and that is the only reason for me wanting to get rid of it.
I did have the compressor housing polished the the hotside jetcoated. I have about $1500 in the turbo.
I would take $950 shipped for it.
--Josh
--Josh
any shaft play, I know how many miles it has but how old is it, when did you buy it and from where? Can the O2 housing welds be removed?
I have had it since april of 06. So about 1 year and 1 month is has been running. I bought it from rnr. And yea the welds can be cut off and you could put anything you needed there. Or even get the 4 bolt flange to weld to a downpipe to bolt right up.
Minimum shaft play. Just a normal amount.
