VIII E85 401whp 362WTQ
Put the EVO on the dyno down at Torque Freaks today and made some good #.
Thanks TF for the dyno time.
Quick list of mods.
-'04 SSL EVO IIIV Stock trubo and hot side
-HKS 272's
-ETS IC and piping with ETS intake pipe
-PTE 780's
-255hp
-E85 fuel
-spike 26psi hold 22psi to redline.
-Flash tuning done buy me.
27psi spike holding 22psi out the top.
26PSI spike holding 22psi out the top.
My Log from the 401whp. As you can see I am using all the 780's but its just enough fuel so I am happy.
Quick list of mods.
-HKS 272's
-PTE 780's
-255hp
-E85 fuel
What's wrong with the torque? The WHP is great, but why is the torque so low when running 27psi? The torque actually climbs from where it normally peaks (3800) to where it actually peaks (5200) It should be higher than the WHP at that boost level, but I do see that you gave it 0 timing at peak boost. Is that on purpose?
Also, did you notice there was no change from 5600-7600rpm between tunes? The 10 AFRs made the same power as the 12+ AFRs. The only power gain with the really high AFR is in the early/mid-range. I suppose you needed to go with the leaner setting, though, to alleviate pressure on the injectors.
Much more timing in the boost spike and it likes to knock so that is just the way it is. On my 1st few pulls when I start at 2800rpm I was geting a good 4-6cts of knock upto 5k. Starting at 3500 really made for less knock that you see in the log.
7.8k is the revlimter which you can tell in the log.
I had it in the 10s from 3k-4k to help with knock I was geting on the street. So I kept leaning out under 5k till I got them in the low 11s which less knock. I really want it low 11s all the way but above 5.5k is all my fuel.
This dyno has allways had low TQ # for EVO's also. I know if I were to dyno 4th my TQ would be a bit higher.
Stock WG acuaitor
Stock WG acuaitor
Quick list of mods.
-HKS 272's
-PTE 780's
-255hp
-E85 fuel
Quick list of mods.
-HKS 272's
-PTE 780's
-255hp
-E85 fuel
