log WGDC in EvoScan
Old Mar 23, 2007, 04:16 PM
mrfred's Avatar
log WGDC in EvoScan
If anyone is interested, I found out last night from Bez, that its possible to log waste gate duty cycle in EvoScan/Mitsulogger. Here is the code that I added to the EvoScan "Data.xml" file:
<DataListItem DataLog="Y" Display="WGDC" LogReference="WGDC" RequestID="86" Eval="x/2" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="100" ChartMin="0" ChartMax="100"/>
For Mitsulogger, add:
<Request LogReference="WGDC" RequestID="86" Eval="x/2" Unit="%" Response="2" logged="Y"/>
This logs WGDC as % duty cycle. For someone trying to control boost with the stock BCS, I think that this can be a valuable tool in figuring out what changes to make.
I'm also seeing if Bez can find a way to be able to log the "turbo boost error correction" value too. That would also be very helpful in controlling boost with the stock BCS.
Edit: Updated for correct conversion factor.
Old Mar 23, 2007, 04:29 PM
RazorLab's Avatar
Nice!
Old Mar 23, 2007, 05:02 PM
Ralph's Avatar
Nice, thanks =P
Old Mar 23, 2007, 05:23 PM
MalibuJack's Avatar
Cool someone posted it.. I was going to post about it this morning but got caught up in something else..
I wouldn't be surprised if every sensor and solenoid/actuator has at least one associated MUT request
Old Mar 23, 2007, 05:28 PM
mrfred's Avatar
Here's a log I took this morning after a bit of WGDC tuning. Still need more work. Trying to get the boost spike under better control and get a smoother boost and load curve.
Attached Thumbnails log WGDC in EvoScan-evoscandatalog_2007.03.23_08.20.05_3rd.png
Old Mar 23, 2007, 08:24 PM
Max Power's Avatar
Great news... are you using this with a drilled pill or totally removed?
Since I'm a little late on this bandwagon, are there any other modified definitions people are using? If so is there any way we could start a combined thread with the modification code and a brief description so someone could look at that and be up to date?
It's nice to see this kind of collaborative effort by the enthusiast... it makes for a great community.
Old Mar 23, 2007, 08:31 PM
AutoXer's Avatar
I've made a list of MUTIII requests here: https://www.evolutionm.net/forums/sh...d.php?t=227779
BTW... this isn't really modified code. It's just info to add the item to many of the loggers out there. It already exists in the ECU of the car. You would add this, or a version of it, to your loggers XML file.
Old Mar 23, 2007, 08:40 PM
RazorLab's Avatar
Have you tried bringing your WGDC % down at 3,000 to combat that spike?
Old Mar 23, 2007, 09:21 PM
mrfred's Avatar
hehe. Just did that this evening. :-) And I raised the MWGDC a bit prior to the spike to promote earlier boost. Seems to have worked. Still have some waviness that I haven't been able to eliminate.
Attached Thumbnails log WGDC in EvoScan-evoscandatalog_2007.03.23_19.45.42_4th.png
Old Mar 23, 2007, 09:38 PM
andenbre's Avatar
you know I saw that on aktivematrix a few days ago but I wasnt sure it was valid since there was little reaction to it, kinda like disabling the rear o2.
Old Mar 23, 2007, 09:49 PM
andenbre's Avatar
correction to the evoscan code for the unofficial .98 release
<DataListItem DataLog="Y" Display="WGDC" LogReference="WGDC" RequestID="86" Eval="x*100/255" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="100" ChartMin="0" ChartMax="100" ScalingFactor="1" Notes="" />
Old Mar 23, 2007, 11:04 PM
Max Power's Avatar
Thanks, I meant a more specific one for each logger and state whether certain upgrades will have that parameter logged (ie - Evoscan - WGDC - Post Code - Not included up to revision 0.98). That way the person can quickly update their specific version and not have to dig around through pages of posts or duplicate something that may be included on a more recent version. It could just be that I'm lazy, but I think it might be helpful for people coming into this fresh so that they're loggers are up to date with all the vets around here.
Old Mar 23, 2007, 11:48 PM
burgers22's Avatar
Hi
this runs Ok in Mitsilogger, I've only run the demo mode as I'm no where near the car, I'm not sure about the scaling thought so please bear that in mind.
<Request LogReference="WGDC" RequestID="86" Eval="100 *x / 255" Unit="%" Logged="y" Response="1"/>
MB
Old Mar 24, 2007, 04:38 AM
cij911's Avatar
MRfred -- What target load / offset are you using and what are your correction factors? The correction factors may be too extreme for your setup, causing the wave. Finally, what load are you hitting in the 3 - 5K range? Thanks
Old Mar 24, 2007, 06:49 AM
mrfred's Avatar
See, that's the beauty of logging WGDC. If you have a look at my plot that you quoted, the WGDC curve is smooth, meaning that the ECU made no sharp WGDC adjustments that could induce the fluctuations in load/boost. (For comparison, have a look at the first plot in this thread where the ECU makes a sharp adjustment in WGDC at 3300-3400 rpm.)
Load (divided by 10) is in the plot. I'm holding about 240 load from 3100 rpm out to 5500-6000 rpm.
Quick Reply: log WGDC in EvoScan
