Tuning the Profec B spec II--simple version
Old Mar 11, 2007, 06:18 PM
belizelittle39439's Avatar
I was looking around online and found that there are still questions about dialing in the Greddy Profec B spec II even with the great write up we already have on this website. So I thought I would post up my findings in how I understand things in an effort to make things a bit simpler for those that still have questions or want a quick reference guide.
Here is a basic chart type setup to aid in figuring things out
(I personally chose to use PSI instead of KPa.)
CONTROL—MEASUREMENT—“EFFECT”—(DETAILS):
Set -- % -- “Desired boost psi”
(Use to set general boost level)
Gain -- % -- “Boost consistency”
(Use to minimize boost taper—proportionately affects the overall boost level)
Set Gain -- psi -- “Boost response”
(Controls when the wastegate starts to open–use to maximize turbo spool up)
Warning -- psi -- “Maximum boost level”
(Sets the maximum boost that you do not want to exceed)
Limiter -- % -- “Maximum boost modifier”
(Sets the amount to reduce the boost psi if warning level has been reached)
Peak Boost -- psi -- "Highest boost achieved"
TUNING PROCESS:
Initial setup: (I was looking for 22 psi)
Set 30% (this should put you at roughly 12-15 psi of boost)
Gain 5 % (this is the lowest setting available)
Set Gain 18 psi (desired amount minus around 4 psi)
Warning 23 psi (I was already running 23 psi w/ ECU control)
Limiter 1% (there’s really no reason to do more than this—the car can easily handle 23 psi with a stock turbo)
  1. Turn off the unit to set it to PSI, then turn the unit back on and turn PEAK BOOST to "on".
  2. Set the WARNING to one above desired boost, and the LIMITER to 1% (or whatever you want).
  3. Start to increase the GAIN first to minimize or remove the taper. In most cases you will not be able to completely eliminate the taper. Increase gain in small increments until boost is held pretty much to redline. If boost spike/surge occurs – go back down in value until it subsides (at this point you’re done with the GAIN).
  4. Adjust for the SET value next—simply by adjusting the percentage until you reach your desired boost levels. In my case that was 22 psi.
  5. Set the SET GAIN value last—the reason for this is because you want to get it as close to the SET value as possible to maximize spool up. Once you hit a boost spike or surge—lower it down till it subsides.
All done!
belizelittle39439 is offline
caz3126 (Jun 13, 2018)
Old Mar 11, 2007, 08:39 PM
LancerEvoMR's Avatar
Discuss thread HERE!
LancerEvoMR is offline
korizmo
Nov 4, 2012 05:19 PM
GregGSC
Dec 8, 2009 09:18 PM
Richard EVO
For Sale - Cars For Sale
31
Feb 6, 2009 06:48 PM
Waz996
May 22, 2006 06:40 AM
evouser12
Mar 5, 2006 07:34 PM
Quick Reply: Tuning the Profec B spec II--simple version
