AEM EMS for Evo 8 & 9
We have a couple AEM EMS for both the Evolution 8 and Evolution IX in stock and ready to ship out to you. We're offering some great pricing on these so hop on this today!!
AEM's Evo Plug and Play Engine Management System (EMS) is a user-programmable full standalone ECU. Replacing your Evo's stock ECU with an AEM EMS is simple, it literally plugs directly into the stock wiring harness. The AEM EMS's Windows-based software makes tuning, injector scaling, and sensor calibration a simple process. User-Defined templates make tuning the AEM EMS even simpler, as you can establish quick keys to speed up the tuning process. While professional tuning is required, the Evo EMS also comes with stock base maps, to get the car running, and speed along the tuning process.
The AEM EMS standalone ECU for the Evo is infinitely adjustable, and with the large variety of available sensors (i.e. MAP, EGT, IAT, etc.) advanced tuners can set vehicles up for advanced, more complex features. Using the optional built-in AEM UEGO wideband, or an external wideband, the AEM EMS has the capability to auto-tune fuel curves. In addition, the datalogging capabilites of this system are second to none.
Features:
PM me if you're interested in one!
Features:
- Direct replacement for factory ECU-No additional wiring or hardware necessary, installs in minutes and uses all the Factory Sensors
- 16/32 Hybrid high-speed processor, NEW Automatic fuel mapping, w/ Onboard 512kb Datalogger
- 10 Cyl Sequential Fuel Injection
- 5 Dedicated Coil Outputs
- 16 General Purpose Outputs
- 7 Definable Switch Inputs
- 4 EGT Inputs w/Fuel Control
- 2 Step Launch Control
- Soft Cut Rev Limiters
- Full Idle Control
- Wet or Dry Nitrous Control
- Definable Knock Control
- Boost and Knock Control
- Forced induction compatible
- Base maps included
- Simplified, intuitive user menus, interactive, user-friendly manual, runs on Windows-based software
AEM Plug and Play
Does this unit work for both EVO IX and IX MR?
I have a IX MR, I need a tunning device that works for the 6 speed. I do not know if there is any difference between 5 and 6 speeds. Please let me know.
