2nd time to the track with new Evo IX...
Last week I ran the car bone stock and did a best of 13.0 @ 102mph with a 1.80 60ft.
This week I added a tbe, mbc, drop in filter and had the car tuned by Andy @ Speed Element all for under $900.
Today my best ET was 12.2, my best MPH was 112.2 and my best 60ft was 1.70
I want to add the O2 housing and a lower ic-pipe and see if I can squeeze into the 11's with the stock cams and pump gas.
My IX has more mods (BR350), and best I could get was 12.6 @ 110 with the stock clutch not holding the power.
You can run 11's with an internally stock IX, it just takes a couple of things. Those parts wont hurt but they by themselves arent going to catapult you into the IX's. Good air, boost in the 25+ range and some 100 octane go a long way to move toward the 11's. Your 60' is decent but there is always room there. Removing the factory clutch restrictor is a worthwhile mod to making the car more responsive on the launch and will help the stock clutch last a little longer. Like I mentioned before weight reduction helps alot.
Very nice. Keep up the good work.
I am jealous to read your posts about going to the track when I am up here in the frozen tundra of Minnesota. I think it is 1 degree F out there right now
I'm pretty sure it will go 11's with a fuel pump, injectors and race gas...
I would love to get my 60's down into the low 1.6's. It would probably give me some 12.1 ET's but it's not easy clicking off 1.6 60's at Sac Raceway.
I already removed my spare tire, jack, tools and don't keep any junk in the car. I'm going to remove my windsheild washer container in the trunk this weekend. I do daily drive this car and wouldn't want to strip too much out of the car. What else do you think I should take out to reduce weight?
How much does my wing weigh?
Good times B.T.W. Pretty good 60ft. on the stock clutch. With a couple more bolt-ons and good weather I bet you could hit 11's on 93.
I wanted to run 11's on pump gas.
More advanced stuff like switching to coilovers (isnt needed but if you are gonna do it anyway) can shave up to 10# or more. Making sure that you are racing with an almost empty fuel tank is important as well. 14 gallons (full) x 6.5 = 91 lbs versus 2 gallons weighing 13, or 78 lb reduction.
