Cosworth IX Camshaft Test Results
Tonight we finally finished our testing with the Cosworth Evo IX Camshafts. We were very happy with the results. All testing was performed on our Mustang AWD Dyno. These are true wheel horsepower and torque numbers. A dyno graph comparison is attached to the thread.
2006 Mitsubishi Lancer Evolution IX MR
2.4L 4G64 Built Short Block
GT35R Turbo
Blitz Induction Cover
Test Pipe
Greddy Titanium Exhaust
Greddy 24V Intercooler
Cosworth 272 11.0mm Camshafts
Works Valve Springs
Works Titanium Retainers
Carbonetic Twin Carbon 1,350KG Clutch
Walbro Fuel Pump
780cc Fuel Injectors
Stock Air Box
Stock Upper Inter Cooler Pipe
Stock Blow-off Valve
Motec M800
27PSI~26PSI
Sunoco GT Plus Unleaded 109
46.7WHP Peak Gain
15.1WTQ Peak Gain
JIC Bullet Downpipe
JIC Spartan Type 2 Ti Exhaust
Works Valve Springs
Everything else stock, including drivetrain.
21PSI~16PSI
91 Octane Pump Gas
22.4WHP Peak Gain
9.6WTQ Peak Gain
GT35R Turbo
Test Pipe
Works Valve Springs
Walbro Fuel Pump
Stock Air Box
Motec M800
27PSI~26PSI
46.7WHP Peak Gain
15.1WTQ Peak Gain
JIC Bullet Downpipe
Works Valve Springs
21PSI~16PSI
91 Octane Pump Gas
22.4WHP Peak Gain
9.6WTQ Peak Gain
I wonder if Evo9 will benefit more by upgrading the wastegate to hold more boost than upgrading cams. It is very difficult to gauge what the Cosworth cams can do in a high modded car like yours.
Wtf, motec m800 on a IX, good gains no doubt, but there is an extra growth of power becasue of the stroker and the other mods + the fact that your pushing 26-27 psi, how about a stock IX test (maybe with a tbe/mbc) on 21psi to see how much it nets
I think what most 9 owners are looking for is on stock 9 turbo & ecu with basic bolt ons with the addition of the cosworth cams and what the outcome of the gains are.
We will post some comparisons with the other more stock IX's from the shop a little later. The car we used for testing has a setup which was able to really show the potential of these camshafts. I'm guessing you guys are looking at it as "If I pay $1,100.00 for cams I could gain this much power or I could pay $100.00 for a boost controller and gain this much power." Well we will see.
You've got to pay if you want to play.
No, I don't think that's what people are saying. I think people realize that you're going to get much bigger gains on a setup like that than on any normal Evo, so the information is not relevant to 99% of Evo owners. If you see the same gains on a bolt-on IX, then they'll fly off the shelves.
I have:
Stock turbo
Stock bottom end
Stock ECU (ecuflash)
Stock Air Box
Stock Injectors
Works Drop-in
Work Apature I TB
Works Down Pipe
Works Cat Back
Works o2
Forge IX Wastegate (red)
Hallman Pro MBC
Walbro 255
ATS Twin Carbon 1350kg
Added:
Cosworth Evo IX cams
Works Valve Springs and Ti Retainers
Cosworth Head Studs
Tomei Cam Gear
My set up is very streetable, and affordable I will have Maxx post numbers after were finished tuning.
Stock turbo
Stock bottom end
Stock Air Box
Stock Injectors
Works Drop-in
Work Apature I TB
Works Down Pipe
Works Cat Back
Works o2
Hallman Pro MBC
Walbro 255
Added:
Cosworth Head Studs
Tomei Cam Gear
I agree. I have a flash/tbe and if I can gain 25+ in terms of power with 10+ at least through the powerband I would be happy.
Or better yet, gets me into the 11's.
