FORGE EVO15 Diverter Valve BLOWOUT!
#78
Originally Posted by TTP Engineering
I am told 34mm.
Also, how long is this deal going for? Not sure if I want to upgrade the bypass quite yet, but maybe soon.
#83
Originally Posted by BigBallin
when do you need to use the shims?? i need to put in the 2nd level spring, and want to know if i need to put in the shims or not. thanks
#86
Originally Posted by Cali2MDevo8
Received product. Left feedback. Nice doing business with you again. I still need to install the downpipe/testpipe that i got from you a couple weeks ago. Thanks
Jason
Jason
#90
OK, crazy twist to this Forge sale:
FORGE Evo 9 Adjustable Wastegate Actuator combo
For you Evo IX owners or those that have beefed up their Evo8 turbo with the new IX turbo, this is for you.
I have 10 special deals that when combined with the limited edition EVO valve will give you the opportunity to add a rare Evo9 WGA for +$169 shipped.
This product is built with a predetermined actuator spring suitable for at or slightly above factory boost levels. The actuator can be assembled with a stiffer spring upon request. Please contact us directly concerning this process.
This product is designed and built with the intent of increasing the boost output of a turbocharged system. We cannot guarantee compatibility with all applications, nor the ability to increase the boost output beyond a level that is within the parameters set by the engine-management-system of the given vehicle at the time of installation, whether that system is factory or aftermarket.
Forge Motorsport nor any of it’s Authorized Distributors can assume any responsibility for any adverse effects resulting from the installation and tuning of this product onto a vehicle whose engine-management-system, whether factory or aftermarket, is not capable of allowing for the desired level of adjustment.
