*New Vendor* - Ksport Coilovers & Big Brake Kits at the lowest prices!!!
*New Vendor* - Ksport Coilovers & Big Brake Kits at the lowest prices ever!!!
Bang 4 Buck Tuning is dedicated to bringing you high quality parts at the lowest prices!
Check out below and PM us for the absolute lowest prices!!!
Ksport Procomp Big Brake Kit --> **Brand new to the Ksport Line**
The Ksport big brake kit includes:
* 8-Piston Aluminum calipers
* High quality brake pads
* D.O.T. Compliant Stainless steel brake lines
* Machined aluminum hats
* Carbon steel brackets
* 330mm (13") large ventilated discs
* Ksport SC5 street brake pads (RC1 race pads available for additional cost)
Regular Pricing: $2120.00 ---> Hundreds and hundreds less!
PM us for unbelievable pricing!
Ksport Kontrol Pro Damper System --> **A Ksport best seller**
Key Features:
* 36-way adjustable dampening
* Made from high quality 6061 Aluminum with T6 for increased hardness
* Compression/Rebound adjustable
* Adjustable spring perch for height adjustment
* Adjustable body allowing maximum suspension travel
* Pillow Ball Top Mount w/ adjustable camber
* Monotube High Pressure Design reduces oil leakage
* Electroplated body for protection from corrosion and rust
* One Year Limited Warranty
Regular Pricing: $1,040.00 ---> We are selling them for hundreds less...
PM for pricing! Too low to advertise!
Ksport GT Pro Damper System --> **Serious Handling and Great Ride**
Key Features:
* Inverted steel shock absorber for durability
* Lower center of gravity and higher chassis rigidity
* Designed to reduce friction for cooler shock oil temperature
* Inverted design like vehicles in WRC and all JGTC cars
Normal Pricing: $1,410.00 --> Hundreds Less!
PM for the best Price! Too low to advertise!
Ksport Version RR Damper System --> **For Serious Track Use**
Key Features:
* Aggressive valving and spring rates
* Reinforced internals
* Race applications only
Regular Pricing: $1,280.00 --> Hundreds Less!
PM for Pricing! Too low to advertise!
We are authorized KSport distributors! Contact us for any Ksport products you need!!!
http://www.ksportusa.com
Key Features:
Key Features:
Key Features:
Originally Posted by MrBubbler
Any reviews on these big brakes?
I am trying to get a set for my car. I will post something up once I have them installed. I believe the rotors are about 20-21 lbs but I will verify.
Originally Posted by jmartinez1170
Let me finsh my one off turbo kit and motor rebuild and i will get a kit. Thanks for for the reply.
