Megan Street & Track coilovers/Exhaust group buy. PM for pricing!!!
Pics thanks to joeymia
The reviews with pics:
https://www.evolutionm.net/forums/showth...Megan+coilovers
https://www.evolutionm.net/forums/sh...egan+coilovers
Must have 10 people paid up for this pricing!
The spiel per Megan:
Megan Racing Coil-Over Dampers are the ultimate upgrade to your track or street car. Featuring 32 Levels of damper force adjustment, full-height adjustment, these damper kits are then perfectly matched with front and rear Pillow Ball upper mounts for camber correction in most applications.
The adjustment of the damper is as simple as can be with a built-in knob at the top of the damper mount for easy access. Simple adjustments can be made to tune to your style of driving and comfort level desired. Single-Adjustable dampers make suspension adjustments easy to tune whether you’re a professional mechanic or an automotive enthusiast with amateur mechanical skills.
The height adjustment is made easy with CNC-Machined locking perches for accuracy and smooth adjustment. You can raise your car up to factory height for OEM appearance with performance handling or you can drop your car all the way down for a formal racetrack and an aggressive stance lowering your center of gravity to gain full potential of your car’s handling capabilities.
On most applications, the Megan Racing Damper Kits come with fully adjustable Pillow-Ball upper mounts to easily tune and adjust your camber. Adjustable camber gives you an edge on most suspension setups, as you can easily tune your car for any ride height which improves handling, predictability and furthermore tire wear, which is a great benefit both on the racetrack and on the street.
The quality and durability of the Megan Racing Damper kits are unmatched. Made of extremely durable Steel and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which are then tested over 500,000 times by compression inspection. With deformation less than 5% and high strength sophisticated surface coating, we stand by our product with our strong warranty.
Features:
- Spring Rates: Street series 8kg/6kg, Track series 12kg/10kg Individually valved accordingly!
- 32 Levels of Adjustable Damper
- Pillow Ball Upper Mounts.
- Rubber Dust Covers.
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cylinder Design
- Aluminum Brackets
32 Levels of Adjustment:
Suggested dampening settings for Street set.
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
- All coilover damper kits come with 1 year manufacture-defect warranty.
- All Hardware is Included
Pricing will not be posted due to agreement with Megan! PM for pricing...
There will be a running list open in the thread. copy and paste the WHOLE list adding yourself as others will do after you. I will keep the paid list in this post as people send in their payments.
Make payment via PayPal to Zeus@zeusmotorworks.com including your CORRECT delivery address, full name, Evom screen name, and choice of Street or Track coilovers.
Failure to include all info above could result in your order being misdirected at your expense.
01)
02)
03)
04)
05)
06)
07)
08)
09)
10)
The Megan Exhaust group buy is back... too!
05-06 catback pics courtesy of Megan
Full Turbo Back (DP/resonated cat delete/CB)
Here are links to the old group buys to see customer comments, a few pics, and to answer all questions:
https://www.evolutionm.net/forums/sh...ighlight=Megan
https://www.evolutionm.net/forums/sh...d.php?t=136943
PM for pricing also!
__________________
Ok... got the price down a little more than what I told the first people who PM'd me. Now the group buy on. Remember, we need at least 10 people PAID up before the orders will ship. With the contacts thus far, I can't see it being that long. Unless like last time, people would rather pay $900 shipped and not wait on the group buy. However, the savings are a bit better this time around.
Everyone has been PM'd
For the two people trying to low ball a price that is set by Megan, and not myself... I suggest you do a search on "Megan" and "Zeus" and see for yourself the difference between my service and some of these other people saving you a few $ who may be here today, and gone tomorrow. Unlike others, I have a day job. I'm not out to make a living at this. I'm simply supporting my Evo "habit" while providing people with a reasonable alternative to the JDM madness. I got into this because I was asked my Megan, and Revolver if I wanted to carry their products (later other "big" names asked me, but were too greedy). I figured that since I was tired of being treated like crap/BULLSHlTED by vendors... that it would be cool if "one of us" were to get into the game and get people Exhaust/Coilovers/Cam kits at reasonable prices. Not only get decent pricing, but be there to help deal with the companies if, and when issues should occur. So far, I've had outstanding luck getting people taken care of after the sale. Matter of fact, people purchased a large amount of Megan products from me last year (at a thin margin I might add). Of the far less than 1% of people who needed a little attention after the sale, I only have two people that did not turn out satisfactory due to the manufacturer. Even though those irk me (and I've not given up on them), I'd say over all my service is a cut above most.
