The best deals on EXEDY, ACT, FORGE, COOLINGMIST, AEM!! COME CHECK IT OUT!!!
Haltech engine management available now!!!
New special-
1x mishimoto radiator for evo 8/9 with gates racing radiator hoses $272 shipped within the 48 states!!!
http://importimageonline.com/imagepr...oducts_id/3234
evo x parts available now!!!
Haltech evo 9 standalone- E11V2 Plug-in - EVO 9 the only available standalone to FULLY control MIVEC!! $1699 shipped
Haltech evo 8 standalone- E8 Plug-in - EVO 8 $1335 shipped!
have a jdm evo? need the wideband conversion? need haltech parts? we can create packages for you!!!
FORGE IN STOCK PARTS-
EVO 8 Wastegate Actuators- $155 shipped (10 of each available at this price)
Evo 9 Wastegate Actuators- $155 shipped
Forge UNOS Manual Boost Controllers- $83 shipped each black or polished
Forge RS recirculating or atmospheric blow off valves- $195 shipped each
Vari-Cool Trunk Mount Kit. The worlds easiest to install and most advanced progressive controller kit. The controller is attached to the tank, so is the pump. Just strap it down. Pump is assembled with fittings and checkvalve. Just run the hose to your engine bay, install your injector (taps from the outside), give the controller power and ground and a boost hose source. Other kits on the market make you mount the pump, tank, controller...this kit makes that a thing of the past.!!
http://importimageonline.com/product...17d35db5e46b85
WE HAVE SO MUCH FORGE STUFF IN STOCK! Help Us get rid of it..whether its in a custom combo of your choice, or individually, and we'll help you on the best pricing anywhere!
Forge Deals-
Forge Recirculating blow off valve for 03+ Lancer Evo- 153 shipped! need a better price? send us a pm
PM for pricing! We have some in black or polished, you choose!
Forge Evo wastegate actuator- PM for Pricing!
Forge Unos Manual boost controllers!!! in black and polished!
Forge In car boost controllers!!! available in black or polished
Forge hoses for evo ALL in stock!!!
FMPFF44-108 Powerflex Mitsubishi Evo 5-9 Rear Lower Engine Mount Bushing $57 shipped!
Or get the FULL motor mount kit!!
features
-FMPFF44-108 Powerflex Mitsubishi Evo 5-9 Rear Lower Engine Mount Bushing
-FMPFF44-106 Powerflex Mitsubishi Evo 5-9 Front Lower Engine Mount Bushing
-FMPFF44-105 Powerflex Mitsubishi Evo 5-9 Side Engine Mount Bushings (2 units required per car
You can get it from us for- $195 shipped!
Check out our new in cockpit manual boost controller!!!!
Forge Unos Manual Boost Controller + Walbro fuel pump combo- $149 shipped!
Forge Unos Manual Boost Controller + Walbro fuel pump combo + Fuel pump install kit - $169 shipped!
Forge Unos Manual Boost Controller + Forge evo recirculating blow off valve +
Walbro fuel pump combo- $288 shipped!
Forge Unos Manual Boost Controller + Forge evo recirculating blow off valve + Walbro fuel pump combo + install kit - $308 shipped!
Forge Unos Manual boost controller + Forge evo recirculating blow off valve combo- $219 shipped!
Forge UNOS manual boost controller + Forge RS blow off valve combo- $263 shipped!
(we have all other forge parts available send pm! tanks, seperators etc)
And the Import Image Racing in car MBC is available as well! Why pay $180+ dollars for the hallman when you can get our in car MBC for less!
Wore out a clutch disc or need a replacement part for your act or exedy setup? send us a PM and we'll hook you up with the parts you need for a great price!
WE NOW HAVE SPEC, RPS, AND CLUTCHMASTERS clutches!!! pm for best pricing!!!!
(all of these fit evo 8 and 9's)
Exedy Stage 1 Clutch Evo 8 evolution-$509.99 SHIPPED
handles 44% more tq then stock
Exedy Stage 2 Cerametallic Clutch Evo 8-$667.78 shipped!
Handles 88% more tq then stock!!!
[/B]
All EXEDY AND ACT CLUTCHES/FLYWHEELS AVAILABLE...LOWEST PRICING is here!!! Send us a PM
ACT Stage 1 Clutch for EVO 8+9-$586 shipped!!!Holds 497 ft.lbs!
ACT Streetlite flywheel- $319.99 shipped!
ACT Prolite flywheel- $349.23 shipped!
Exedy stage 1 + ACT streetlite flywheel Combo- 779.99 shipped!
Exedy stage 1 + ACT prolite flywheel Combo- 809.99 shipped!
Limited time only-
ACT Stage 1 Clutch + ACT streetlite flywheel Combo- $897.99 Shipped!!!!!
ACT Stage 1 Clutch + ACT prolite flywheel Combo- $915.99 Shipped
For more Coolingmist water injection kits check out
www.importimageonline.com
Our best selling Water Injection kit!!!-
Coolingmist Stage II retails for $499.95. Your price $444.99 shipped!
* 2 Quart Tank
* Vari-Cool Coolingmist Controller
* Complete Kit!!!
* No Need To Specify Horsepower!
The Stage II controller kit is a fantastic value. You recieve our high pressure pump, vari-cool tuning controller, a 2.0 quart tank and everything else you need. The controller has a starting point for boost, a maximum point for boost and a tuning knob. The tuning knob gives you 10 algorithms to choose from. For example, if you set the minimum knob at 1 and the max at 30 and have the tuning knob at 1 it will give you a linear feed from 1-30 psi. The higher you change the tuning knob the more agressive the curve. Because of this, you do not need to change injectors when you gain more HP. Our software suite allows you to change the variables in the controller so you can fine tune if you wish. Software requires windows 2000, NT, 2003, or XP +. The controller has a 0-5V input also, so if you prefer to inject the water based on the 0-5 instead of the boost, you can do that also. What else can this unit do? Lets say you want to run based on both 0-5V input and Boost...You can set the 0-5V as the primary input and the boost as secondary or you can set the boost as primary input and 0-5V as secondary. You must have the software configured to run that mode.
Stage III Coolingmist kit- 534.99 shipped
Coolingmist Deluxe kit- $279.99
upgrade to a 1 gallon tank with any kit ordered for only $20!
Add a float level indicator and led light for only $20 with any order!
Varicool controller only $222.99 shipped!
turboxs sale continues!!! as well as perrin. PM for pricing!
Slowboy racing-
Front mount intercooler with upper and lower piping- $1009 shipped
Front mount intercooler Lower pipe only- $759
Greddy intercoolers as well as hks also available
Other parts-
- APS FMIC Blow Off Valve shipped $259
-Magnus intake manifold For Evo 4-8 $699
-Helix Oil Catch Can $81.50 shipped
-HKS camshafts 264..272..combo..straight 272 deal, whichever- $xxx shipped
We are very competitive with our pricing
Savings on items paid for via Money order, Certified Bank check, and personal check (shipped after check clears) receives additional discounts
Regards,
Sales@importimageracing.com
Import Image Racing
www.ImportImageonline.com
Formerly www.importimageracing.com
239 540 6385
Paypal= Whtezmbej@aol.com
Money order address=
Import Image Racing
431 sw 34th terrace
cape coral, fl 33914
New special-
Forge Deals-
features
[/B]
Limited time only-
* 2 Quart Tank
* Complete Kit!!!
Slowboy racing-
Other parts-
Regards,
Import Image Racing
239 540 6385
Import Image Racing
431 sw 34th terrace
send us a pm on the entire product line. Our turboxs, power enterprise and forge discounts have risen, meaning even more savings for you! PM us for details or give us a call! we won't be beat!
Nov 15th + 16th Cobb Accessports will be here! 400lbs worth! hehe! get yours today from us and save! call for details 239 540 6385
i have EVO turboxs utec's in stock with the new software...for sale cheap! send us a PM! We'll just say you can get a turboxs Utec + map selector WAY under 850 shipped! We also have the entire line of turboxs products in stock ready to go! our sales are incredible. if your serious about buying, we are serious about hooking you up!
POWER THREAD-
We will beat anyones pricing on forge products
NEW PART!
Coolingmist trunk mount + varicool stage 2 kits are on super sale!!!
PLX WIDEBAND (GAUGE TYPE) unit + gauge= 255 shipped this month!!!
Perrin 3inch stainless steel high flow cat pipe-
IN STOCK
So you've been wanting to hear a turboxs turboback exhaust on an evo ix...here it is-
http://s88.photobucket.com/albums/k2...t=P9180058.flv
New special!!! Crower Cams stage 2-4 and valvetrain-
http://importimageonline.com/index.php?cPath=170_23_60
Apexi AVC-R Boost Controller- 459 shipped special!!!
Apexi SAFC NEO- $339 shipped special!!
Forge Unos Manual Boost Controller + Forge evo recirculating blow off valve + Walbro fuel pump combo- $288 shipped!
TITEK 02 Housings- $203.15 send us a pm! or give us a call they are always in stock
Avid 2 piece motor mount replacement (www.avidracing.com) i can do 349 shipped on a set! for evo 8 + 9
We now carry Invidia products! pm for the deals
Blitz SBC I-Color Boost controller
695 shipped for Evolution M members!!!
CRAZY AEM STANDALONE ENGINE MANAGEMENT SALE....LIMITED TIME ONLY!!!! PM for pricing!!!- If your serious about buying, we are serious about moving them outta here!!!!
To start off the deals-
In stock- Walbro GSS342 Fuel Pumps! Need the install kit too? Fits Evo 7,8,9 and every variant model. ...Best pricing ANYWHERE! beware, some vendors are selling without the install kit. That blows away there price be smart!! just send paypal
confirmed to whtezmbej@aol.com
92.99 shipped for walbro fuel pumps with install kit
77 shipped without install kit
If your in a hurry for a fuel pump you can just pick one up here
http://www.importimageracing.com/ind...Path=170_23_63
Have a crazy setup? Need a dual walbro pump setup? 176 shipped for dual pumps!
We have every model in stock. If you order one from us, it ships either that day or the next! Have a dyno day planned or you just need it overnighted? We will help you get your parts when you need them!
MORE SPECIALS- IN STOCK
Competition Clutch – Evo Flywheel – 259 Shipped
Brian Crower – 272 Evo Cams – 3xx.00 shipped
280 Evo Cams – 3xx shipped
Buddy Club – Prospec Evo Exhuast – 519 shipped
Fujita – Evo Intake Includes Upper/Lower IC Short Ram – 4xx shipped
Apexi -
Noir World Sport Muffler EVO – 499 shipped
N1 Muffler EVO – 519 shipped
N1 EX Ti Muffler EVO – 849 shipped
Avid Mounts - Evo Direct Replacement Upgrade Mounts – 379.99 shipped
This are direct bolt on and are solid billet aluminum is stiff *** mounts. A must have for this seasons fashion.
Power Enterprise – Timing Belt for Evo – 151 shipped
Tial - 50mm BOV – 229 shipped
44mm wastegate – 369 shipped
Be sure to check out our combo deals on our website, we are always thinking of new packages to save you money! www.importimageracing.com
Turboxs Parts-
Turboxs EVO Complete Catless Turboback TI tip exhaust- $789 shipped
TXS Downpipe- $289.99 shipped
TXS TI catback- $515 shipped
TXS intake- $119 shipped
Turboxs Tuner Pro with Bosch sensor- $635 With Free Shipping
TXS Wideband Air/Fuel with Bosch Sensor- $459 shipped
TXS Wideband Air/Fuel with VW sensor- $369 shipped
TurboXS Evo Utec- $ PM us!
TurboXS FMIC- $PM shipped
TurboXS Dtec Starter Kit (DTEC-STARTER) $219.00 shipped
TurboXS KnockLite (KNOCKLITE) US$124.00 shipped
TurboXS Fuel Cut Defender - 5 volt MAP (FCD - 5V) $124.00 shipped
Turboxs Dtec Fuel Computer (DTEC-FC) (Dtec FC) US$338.00 shipped!
Turboxs Dtec Fuel Computer/Turboxs Bosch Tuner COMBO!! $726.00 SHIPPED!!!!
TurboXS Dtec Starter Kit/Turboxs Bosch Tuner COMBO!! 639.99 shipped!!!
The TurboXS DTEC is a revolutionary new product that turns your Nintendo® Gameboy Advance into a programmable, upgradeable, automotive performance tool for tuning, data logging, and diagnostics.
Turboxs DTEC Boost Controller Pro (DTEC-BC-PRO) US$PM ONLY! We have the best pricing on this item!
The DTEC-BC-PRO is quite simply THE BEST boost controller ever made. It turns your Gameboy Advance SP into a powerful Electronic Boost Controller cabable of controlling boost pressures in excess of 60psi. The DTEC-BC-PRO allows everything from simple "one number" boost control that can be set up in minutes to the most advanced closed loop, gear dependant, RPM, and throttle position based programmable boost controller ever conceived. It comes standard with 60+psi cabaple inline boost control solenoid; 45psi MAP sensor; KnockLite detonation detector and more. Advanced features include the ability to store and switch between five (5) different boost maps; scramble mode; overboost protection; "start boost" feature to speed turbo spool up; and gain control. You even have the option of adding a second solenoid (sold separately) to completely control pressure to both the top and bottom of you external wastegate for the ULTIMATE in high boost control. These are features you will not find in the $680 Greddy E01; the $655 Blitz SBC-id; the $629 Apexi AVC-R; or even the $725 HKS EVC V.
The Gameboy Advance SP is not included. While it is required to set up the boost controller you do not have to leave it plugged into the DTEC-BC-Pro.
Crazy Combo's with free shipping!-
Turboxs Utec + Map Selector + Dtec Boost Controller Combo- 1289.00
Turboxs Utec + Map selector + Txs Bosch Tuner Combo- 1,259.00
Turboxs Utec + Map selector + Walbro Fuel Pump combo! 940.99
Perrin Performance-
Inlet hose (turbo to maf) $226 Shipped!
radiator hose kit $149.99 shipped
FUEL RAIL KIT FOR Evo $181 shipped
Perrin Front mount intercooler- $774 shipped
DOWN PIPE NO-CATS 2003+ EVO (OFF-ROAD ONLY) $266.99
EXHAUST SYSTEM CAT-BACK 2003+ 599.99 shipped!
Test pipe for evo 8+9 with 02 simulators $169.99 shipped
Turboback 3inch exhaust combo featuring all 3 items- $1019.99 shipped!
Exhaust silencer available!
NEW Evolution 816cc injectors- $576.99 shipped!
Lightened Crank Pulley for evo $109
BLOW OFF VALVE KIT $200.99
Perrin catchcan $124.99 shipped
Dual column mount gauge pod- $124.99 shipped
Boost tube kit- $252 shipped
Intake system (filter + mount) $155 shipped
Short ram intake system- $252 shipped
Boost tube lower hardpipe- $125.99 shipped
Manual boost controller $79.99 shipped
EBCS boost controller $85.00 shipped
Short shifter- $167 shipped
Combo's available!
Coolingmist water injection kits available!!
for more info, follow this link- http://www.importimageracing.com/ind...ecc1d8713181a5
Slowboy Racing complete GT35R turbokit for the Lancer Evolution!!!! Kit comes with- Stainless Steel cast manifold and SBR Stainless Steel cast O2 housing with turbo lines, intake, intercooler piping, its $3469 shipped and in stock!!!
BIG SPECIALS...SEND PM FOR DETAILS!!!!
fmic specials as well!
Its so pretty!
Of course thats the test model, yours will be even better looking!
Want a GT37R? Add $195...we do have some specials going on so send us a PM
Slowboy Racing's GT35R+ turbokit for the Lancer Evolution!!!! Kit comes with- Stainless Steel cast manifold and SBR Stainless Steel cast O2 housing with turbo lines, intake, intercooler piping, Tial wastegate, Tial Blow off valve, Slow Boy Racing Intercooler + lower pipe and free shipping! $4495!!!
If you would like a different turbocharger, please send us a message and we can substitute a smaller turbo for you.
This kit bolts up to your aftermarket downpipe! no need to buy one. Why purchase a Full-Race turbo kit when this setup is from the highest quality and is $1000 less!!!!
Power Enterprise Injectors-
call for pricing
Injector, fuel pump, turbocharger packages available! send us a PM
Turbochargers-
SBR Full Garrett Ball-Bearing T3 GT10-$1159 shipped
SBR Full Garrett Ball-Bearing T3 GT11-$1159 shipped
SBR Full Garrett Ball-Bearing T3 GT12-$1159 shipped
SBR Full Garrett Ball-Bearing T3 GT13-$1159 shipped
SBR Full Garrett Ball-Bearing T3 GT14-$1159 shipped
SBR Full Garrett Ball-Bearing T3 GT30R $1189.99 shipped
SBR Full Garrett Ball-Bearing T3 GT35R $1425.99 shipped
SBR Full Garrett T4 GT40R- $1959 shipped
Turbonetics T3/T04E Hybrid $739.00 shipped
Turbonetics T3/T04B Hybrid $739.00 shipped
Innovative turbochargers also available!
Slowboy racing-
Other parts-
-why buy SMC, they take forever to arrive, pick up a Coolingmist.com varicool water injection kit for less money and get better products and customer service!!
http://www.importimageracing.com/ind...ce6518260e9c6d
Import Image Racing
www.ImportImageRacing.com
239 540 6385
431 sw 34th terrace
Cape Coral, FL 33914
POWER THREAD-
NEW PART!
IN STOCK
Apexi -
Turboxs Parts-
Perrin Performance-
Combo's available!
Its so pretty!
call for pricing
Turbochargers-
Slowboy racing-
Other parts-
Import Image Racing
239 540 6385
431 sw 34th terrace
Hallman boost controllers added to our website!
check it out!
http://www.importimageracing.com/ind...Path=170_23_71
check it out!
Monday morning bump!
