$5 o2 cheater/non fouler how-to
Old Jun 24, 2006, 10:10 PM
Hkysk8r07's Avatar
Available at your local automotive store. Spark Plug Non Fouler PN 42009 ($4.99)
You now need to drill out 1 of the non foulers using a 1/2" drill bit. When finished this is what it will look like.
Side by Side comparision of the orignal and now modified non foulers
o2 Sensor inserted in the modified non fouler
Second, unmodified non fouler now installed on modified non fouler
Original non fouler->Modified non fouler->o2 sensor
Fully installed
The idea behind it is when you remove the cat the 2nd o2 sensor is going to have too much crap reaching the sensor that isnt filtered out, which will make it think the cat has gone bad. What this does is it moves the o2 sensor further away so a limited amount of exhaust gets to the o2 sensor, it is a VERY little ammount that actually gets to the sensor but as long as it is considerably less than the primary o2 sensor then it wont cause a CEL.
from (http://www.k-series.com/forum/showthread.php?t=8833) pics rehosted by me incase the thread/pics disappear.
saw a few threads asking how to do it so i found it done w/ pics and decided to pass along the info
Old Jun 24, 2006, 11:30 PM
EvoIXMR's Avatar
what part store did you buy it from?
Old Jun 24, 2006, 11:45 PM
Registered User
kimletrim's Avatar
Isn't there a How To on this already? But nice pics and writeup.
Old Jun 25, 2006, 05:00 PM
Hkysk8r07's Avatar
i didn't buy it... it's not my write-up if you read it completely you would know that. and it's any parts store. autozone, pep boys, napa, kragen, CPK, etc. etc. just go to the counter and ask for the "spark plug non-fouler"
didn't see one in here which is why i posted it. plus it shows the people with no idea what a tool is how to actually do it. :
Old Jun 25, 2006, 05:31 PM
EnJaNir's Avatar
That is my write up I did a handful on years ago that I hosted on ephatch.com k-series.com i-vtec.net crsx.com and a handful of other Honda boards
I find it amazing how many forums my images/writeup has ended up on without any attempt to contact me before posting them.
Old Jun 30, 2006, 11:17 AM
Tainted Winter's Avatar
you can get the at Autozone on the "Help" ilse. That is where I got mine and plan to install soon.
Old Jun 30, 2006, 01:57 PM
doublewide's Avatar
Well do i have your permission to use this method or do i need to go to one of the other boards; read the how-to then use it
Old Jun 30, 2006, 03:21 PM
EvoG8r's Avatar
I've had this in my car for a few months and I have never had a check engine light for exhaust.
It works.
Old Jun 30, 2006, 10:35 PM
EVOpacoIX's Avatar
just used it today on my IX..... we'll see....
Old Jun 30, 2006, 10:40 PM
mr96gsx408's Avatar
i did it and it works
Old Jun 30, 2006, 10:47 PM
Silk's Avatar
What are the real use of spark plug anti foulers. Do you screw them into your cylinder head and then put your spark plug in What does it mean to "anti-foul"
Old Jul 1, 2006, 09:10 AM
EnJaNir's Avatar
It tries to keep the charge away from the plug to prevent fouling or missing.
Old Jul 1, 2006, 05:06 PM
I followed these step exactly (well, based on some common sense and a 1/2 bit and a vice) and the conclution is...
I have now installed this quick fix and it worked! I went to get the codes pulled to erase them and I had 5, mosly from vacuum rerouting and emission. All gone and it didn't come back when I gave the ole lead foot. We shall see but this looks very promising...
Old Jul 26, 2006, 10:31 PM
BlackLancer2k2's Avatar
i will try this also...thanks!
Old Jul 28, 2006, 07:08 PM
DrivenToThrill's Avatar
OK dunb question here.....does that say 16 mm or 18mm?
d-
Quick Reply: $5 o2 cheater/non fouler how-to
