2.4 block and Evo head?
Originally Posted by Stew
..and post some numbers joey!
https://www.evolutionm.net/forums/sh...d.php?t=213081
I made about 340hp and 340trq at around 19-20psi (Dyno was reading boost way to high). We had some problems with the knock sensor detecting knock that wasn't there. My car has solid mounts, balance shafts removed, and a noisey Tilton twin plate clutch. All that causes the knock sensor to freak out. Some runs it would detect 35 counts (which is max I think) at just 3k rpm. To make more power I need to play with the knock filters. Before I do that I need an electronic stethoscope so I can listen to the engine while I tune it.
If anyone knows where I can get a good electronic stethoscope so I can tune this please let me know
pledgekincaid (Jun 22, 2020)
Originally Posted by joeymia
I did reuse the evo oil pump. I was using a 4g64 water pump but the damn thing which I bought brand new from Advanced Auto parts was defective. I went ahead and just reused my evo water pump with a adapter plate which i made. The timing belt I got real lucky on... I ordered the wrong timing belt from JAM. I ment to order an Evo8 one and I got a 2g dohc one. This was before I knew I needed to get a different timing belt
Most people doing this in the DSM world use the timing belt from a 1994 Galant GS.... the only 4g64 DOHC produced by Mitsubishi, along with the cam gears from the 1994 Galant GS.
The cam gears wouldn't do us any good, but the belt would be the correct length.
Also, for the DSM's the 4g64 block has some extra water passages that are not in the 4g63 head that need to be blocked off.... is it the same story with the 2000 and up Eclipse 4g64 block compared to the EVO head?
Keith
Originally Posted by Fourdoor
Are you saying that the timing belt from the 420A non turbo used in the N/A 2G DSM's is longer than the 4g63t timing belt?
Keith
Keith
Honestly I have no idea how I ended up with the right belt... I ordered a timing belt from JAM for what I thought was an Evo8 and ended up with the belt I have now. I forgot to mention the 3 water passages, those of course were blocked off.
Originally Posted by sonicnofadz
You will need a belt from a 94 galant...2G DSM belt won't work. I think you also need cam gears from the galant as well, but I am not 100% certain.
Correct me if I'm wrong, but from the brief information I've gotten from this thread, if I understand correctly, all that is needed to use the actual 4g64 (2000+ Eclipse) block is to block those coolant passages and to custom a bracket for the water pump? If so, that should be simple enough like the 7 bolt DSM 2.4s.
The 2g Spyder belt wont work because that motor is still SOHC. As someone said earlier, the 94 Galant GS was the only DOHC 4G64 ever made, so that belt is the correct length. Here is some food for thought. The guys with the 00-05's eclipse's with EVO heads are using stock EVO timing belts on their cars, and it works. One of them, RRE built the motor, so they wouldnt make a silly mistake like that, so I guess the stock belt is fine. What you do need is adjustable cam gears. Since the 4G64 block is taller, it makes the timing marks on the cams out of alignment. I am not sure if the 94 Galant GS cam gears will bolt to EVO cams, if they do, those could work. I am in process of doing a 2.4 build right now, I had a JDM EVO7 motor in my 99 galant. You can use any 4G64 block from a galant from 99-03 and eclipse from 00-05. I still dont know why you need a water pump bracket. I know the actual dimensions and bolt pattern of the galant/eclipse pump and EVO pump are different, maybe this bracket allows you to use your EVO pump instead of needing a galant/eclipse one. The galant/eclipse also uses 2 accessory belts instead of a single serpentine belt. 1 belt goes around the crank, idler, p/s pump and a/c compressor, the other goes around the crank, alternator and water pump. That could also be a reason for this bracket. The stock 4G64 crank is forged like the EVO. Aside from what many people believe about the stock EVO crank being nitride coated, it is NOT nitride coated from the factory. Everyone likes to jump on the "cant grind down the crank because then you cut away the nitride coating and the crank isnt strong" bandwagon. I actually sent my EVO crank to the machinist to get polished and he calls me and says " Are you sure you wanna use this crank?" I aksed him why, and he said the crank isnt nitrided. This was a stock, never cut, evo crank. So I actually bought a 2g DSM crank and used that since it was nitrided. The 4G64 cranks are also not nitrided. The only ones that are, are the ones that Eagle sells. I totally thought the thing about the stock EVO crank not being nitrided was BS and my machinist might have been drunk or high when he called me, but I actually called FFWD connection and RRE and I was told the same, and they are both reputable DSM builders. I should have my motor completely done within the next 2-3 weeks and the car should be in the streets again by end of september.
and I also just confirmed that you dont need to block off any of the holes. Everything lines up with the coolant and oil passages. Checked visually with the 63' h/gasket on the 64' block. and I confirmed that some of the turbo 4G64 SOHC guys are running EVO cometic head gaskets. On a 6 bolt or 2g 7 bolt DSM you need to block off holes, not for the newer ones with the EVO head.
Originally Posted by VTEC Killer
Here is some food for thought. The guys with the 00-05's eclipse's with EVO heads are using stock EVO timing belts on their cars, and it works. What you do need is adjustable cam gears. Since the 4G64 block is taller, it makes the timing marks on the cams out of alignment(edit-time).
for the 4g64 block to evo head, you can use the factory evo timing belt, but its really tight. then degree the cams to the crank with the adjustable gears (appx.-4*/-4*).
the water pump is the biggest issue imo.
most companies provide an "adapter plate" (errr plasma cut sheetmetal) that doesnt work very well. basically the block water passage on the 4g64 is larger than the evo h2o pump housing. so, i fastened the pump housing down on my welding bench and welded more aluminum in this area of the pump housing to create a larger "flange" and cover the exposed water passage. then using a silicone injected paper gasket material, made a custom gasket.
works like a charm.
i can tell you from experience that the "adapters" don't work very well. i can change the water pump on our car in about 45 min now lol
Ken
edit: as far as the 00-03 eclipse, i think the issue is the actual block casting(engine mount, ac mount, ps mounts) being different, not sure though.
i do know that the Lancer rally art model 2.4L mivec sohc block works perfect.
works like a charm.
Ken
works like a charm.
Ken
as far as the issue with the 00-03 eclipse, the different with the mount is this. The piece of the mount that bolts to the motor has those three studs coming off it, on the eclipse, the middle stud is opposite of how it is on the EVO, the other 2 are the same. There is no true harm in just taking the middle stud out and not using it, as long as you torque the other 2 down to spec, it wont be in issue. I had to do that when I put the EVO motor in my car and I never had any problems with it.
anyone who has any info about this particular topic, please post up, it seems we are getting alot of good info here that will be helpful to others in the future. this may be a future "sticky"
2.4 liter Galants 02 and up iron 2.4 bolts up to the evo head. Modifications to the block will require some oil squirters like our stock block has. Also custom pistons and rod are in order.Water pump you will need some fab skills.
You have a 2.4 iron block monster.
I posted pics of my motor with the head gasket from the 4g63 on the 2.4L block. Just search for 2.1L pics.....or look under my name for topics I started. Also, the adaptor plate for the water pump. I can take a pic later on today as I have it sitting around. From what SBR has told me I needed the longer timing belt and the adjustable cam gears to make everything work as far as head/block combo go. Timing belt PN they sent me is md182292 anyone know which one it is (model year?)
