Evo 'For Sale' Suspension / Brakes / Handling Includes pads, rotors, springs, shocks, swaybars, and other handling related components.
Large Sway and Strut Bar Sale (Cusco, Mines, etc.) - F+R CF Strutbars - $299 shipped!
Old Aug 2, 2006, 06:02 PM
Gruppe-S's Avatar
Aerosync Carbon Fiber Strut Tower Bars
The Aerosync Carbon Fiber Strut Braces are the perfect compliment to a set of coilovers or even springs, as they offer an increase in rigidity as well as a significant improvement in vehicle handling. These particular pieces are made of real dry carbon fiber, and feature an adjustable length for personal stiffness adjustment. The Front weighs in at a feather-light 2 lbs. and 7 oz. while the rear is an ounce over 2 lbs. If weight is a concern when considering suspension components, the Aerosync Strut Braces are a certain contender.
$149 Shipped for Front!! - $179 INSTALLED!!
$199 Shipped for Rear!! - $229 INSTALLED!!
$299 Shipped for Both!! - $359 INSTALLED!!
Cusco OS Front
Lightweight aluminum and high rigidity oval sectioned pipe used.
- Hollow core aluminum shafts for lightweight
$185 Shipped!! - $215 INSTALLED!!
Cusco Ti Front
Improves chassis rigidity and reduces flex and weight by 60% lighter compared to most other bars.
- Full 100% titanium construction with TIG welds
$299 Shipped!! - $319 INSTALLED!!
Cusco OS Rear
$149 Shipped!! $175 INSTALLED!!
CUSCO Ti Front and Cusco OS Rear Strut Bar - $439 Shipped!! $489 INSTALLED!!
Cusco OS-T V-Brace
Cusco V-Brace works in conjunction with a Cusco Type-OS or Type-CB strubar to improve chassis rigidity and reduce this flex.
$99 Shipped!! $139 INSTALLED!!
Cusco Rear Sway Bar
Stiffer swaybars properly distributes cornering forces by reducing lateral sway, and will ultimately increase vehicle turning characteristics.
- The rear sway bar will increase oversteer and allow the car to turn tighter
$245 Shipped!! $275 INSTALLED!!
Cusco V1 Lower Arm Bar
The purpose of the Cusco lower arm bar is to reduce alignment flexing and improve body rigidity.
$69 Shipped!! - $119 INSTALLED!!
Cusco V2 Lower Arm Bar
The Version II Bar mounts by multiple bolts and rigidity is greatly increased over Version I.
$149 Shipped!! - $199 INSTALLED!!
CUSCO V1 and V2 LAB$199 Shipped!! $259 INSTALLED!!
Mines 6-Point Lower Arm Bar
This lower arm brace mounts onto multiple points on the front supsension/chassis to greatly increase overall chassis dynamics, and reduces alignment flexing and increases body rigidity.
- High tension lightweight aluminum
- Finished in bright silver color
$299 Shipped!! - $325 INSTALLED!!
Regards,
Mark
Gruppe-S is offline
Old Aug 3, 2006, 04:35 PM
jbrown's Avatar
I would LOVE to buy some of these parts from you if you would reply to my PM!
jbrown is offline
Old Aug 3, 2006, 04:52 PM
Gruppe-S's Avatar
Sorry, read yours and got pummled with phone calls but you got your PM!!
Regards,
Mark
Gruppe-S is offline
Old Aug 3, 2006, 04:59 PM
jbrown's Avatar
SOLD!!!
Thanks man, awesome deal!
jbrown is offline
Old Aug 10, 2006, 11:00 PM
Gruppe-S's Avatar
Sold out of the Cusco V1 bars... but we've got plenty of everything else IN STOCK
Max
Gruppe-S is offline
Old Aug 15, 2006, 12:26 PM
justchil's Avatar
Is the Cusco Rear sway 23 or 24mm? Does it include all hardware needed for install? Any combo's with rear strut bar? Thanks
justchil is offline
Old Aug 16, 2006, 10:23 PM
Gruppe-S's Avatar
justchil - It's a 23mm adjustable bar and does include new bushings needed for the install. Which rear strutbar did you want to combo with?
Max
Gruppe-S is offline
Gruppe-S
44
Feb 28, 2007 02:08 PM
Gruppe-S
Dec 12, 2006 11:24 AM
Gruppe-S
17
Nov 30, 2006 06:06 PM
Gruppe-S
Jul 11, 2006 01:16 PM
Gruppe-S
Jul 7, 2006 08:31 PM
Quick Reply: Large Sway and Strut Bar Sale (Cusco, Mines, etc.) - F+R CF Strutbars - $299 shipped!
