Evo 8 spark plugs do not fit a 9
So apparently the BPR7ES plugs from NGK won't work, and if it's the standard size plug for an 8, then it will not properly fit a 9 because of the MIVEC head..
They're too short and the threaded end, and tool long at the ceramic end. The coil packs sit 1/4" too high and can't be bolted down.
Plugs that are known to fit our beloved IX's:
NGK ILFR7H (OEM) Iridium
http://www.sparkplugs.com/more_info.asp?AAIA=&pid=20451
NGK LFR7AIX Iridium
http://www.sparkplugs.com/more_info.asp?AAIA=&pid=16602
What a pisser. Here's a pic highlighting the seating point as this controls how deep it goes. Boo hiss.
NGK LFR7AIX Iridium
Originally Posted by EvoVIII_MR2005
This topic has been covered several times on the boards...Only HKS has sparkplugs out for the 9.
Keith
Originally Posted by Fourdoor
A link for the EVO IX guys to that thread, or a link directly to the HKS plugs would be appreciated. We are trying to be a friendly community here and help each other right?
Keith
Keith
So this is as difinitive as I could prove it, because yes, it's been discussed many times before, but nothing was really 100% believable proof (from what I found) because there's so much muck and garbage to sift through on this board.
edit-
BTW HKS's site says nothing about plugs for the IX. If theire generic applications do match, I'm still not paying $21 per piece.
Originally Posted by Wheelhaus
^ Yes. If anyone does this before me please post brands and model numbers and I will edit them into the original post.
Originally Posted by cbrtrx
i guess you missed my post , ngk lfr7aix , retail for $8 each and handle the high boost better then the stock ones
Originally Posted by housedj
yup the IX plugs are 7mm longer than the VIII's due to the taller head. they needed space for MIVEC & to eliminate "lifter tick"...
The only benefit I see of a taller surface between the top of the combustion chamber and the base of the spark plug valley is more room for cooling passages, which makes much more sense than an effort to eliminate "lifter tick".
Originally Posted by SuperHatch
Where is the documented source you heard this from? I.E. - Mitsubishi Engineering Documents. Because until you do, this is completely conjecture, and very poor at that.
edit- nevermind, you were responding to why they're taller, not if they actually are.
