Blowout! In Stock Items!
Ok guy's i am making a list of EVERYTHING i have in stock for your ride. This stuff needs to be turned over. Please PM and i will be happy to shoot you over a price. First come first serve.
Just added HKS DLI II- $469 shipped.
ACT 600205 2003-05 Evolution VIII 13.1lb Flywheel
AEM 23-831B 2003 Mitsubishi EVO Cam Gear Blue
AEM 30-1313 EMS Mitsubishi Lancer 2003 EVO VIII
AEM 30-4100 Six-In-One Gauge Type Uego Controller
AEM 30-4300 19 Channel Serial Datastream Gauge, includes interchangeable
bezels, pin guides
APX 403-A053 E.L. II Gauge Meter Control Unit
APX 403-A955 E.L. II Gauge Boost Kpa White
APX 403-A956 E.L. II Gauge Oil Temp Black
APX 403-A957 E.L. II Gauge Oil Temp White
APX 403-A958 E.L. II Gauge Water Temp Black
APX 403-A959 E.L. II Gauge Water Temp White
APX 403-A962 E.L. II Gauge Oil Pressure Black
APX 403-A963 E.L. II Gauge Oil Pressure White
APX 420-A904 Avc Type R Boost Controller
ARC CTUSU05 Universal Oil Catch Tank - 15mm
BM 45186 03-Up Evo VIII Shifter
BLI 15058 Dual Spec Boost Controller Spec S Single Solenoid
BLI 19280 Gauge Link - DC Live Unit 2
BLI 19281 Gauge - DC2 Boost Meter 2.0 Bar (Carbon)
BLI 19282 Gauge - DC2 Boost Meter 2.0 Bar (White)
BLI 19284 Gauge - DC2 Temp. Meter Oil/Water (Carbon)
BLI 19285 Gauge - DC2 Temp. Meter Oil/Water (White)
BLI 19287 Gauge - DC2 Pressure Meter Oil/Water (Carbon)
BLI 19288 Gauge - DC2 Pressure Meter Oil/Water (White)
BLI 19322 Gauge BLM Temperature Oil/Water Carbon Face Black Light
BLI 19323 Gauge BLM Pressure Oil/Fuel Carbon Face Black Light
BLI 19324 Gauge BLM EX. Temp EGT Carbon Face Black Light
BLI 19444 Gauge - DC2 Exhaust Temp./Rpm (Carbon)
BLI 19445 Gauge - DC2 Exhaust Temp./Rpm (White)
BLI 19451 Mirror Drive Oil/Water Temp Carbon 60mm
BLI 51153 1993 - 96 Supra Turbo Timer Harness
BLI 51201 1989 - 94 Eclipse/3000 GT Turbo Timer Harness
BLI 51203 1995 - 99 Eclipse Turbo Timer Harness
BLI 51251 Turbo Timer Harness 1993 - 95 RX7
BLI ZZ3001 Blow-Off Valve Steel Flange
BLI ZZ3002 Blow-Off Valve Aluminum Flange
BRE 1B1.8038A2 GT Brake Kit -- 1999 - 04 Mitsubishi Lancer EVO VI, VII, VIII 18" wheel required 14.0 dicc size (328mm) Red
BRE 2C1.6007A2 GT Brake Kit -- 1999 - 04 Mitsubishi Lancer EVO VI, VII, VIII 18" wheel required 12.9 disc size (328mm) Red
BRI M019FG 2000> Mitsubishi Evo 7/8 Seat Rail Right Full Bucket
BRI M019RO 2000> Mitsubishi Evo 7/8 Seat Rail Right Reclining (ErgoII)
BRI M020FO 2000> Mitsubishi Evo 7/8 Seat Rail Left Full Bucket
BRI M020RO 2000> Mitsubishi Evo 7/8 Seat Rail Left Reclining (ErgoII)
BRI F33AMF Exas III (Black)
DC MCR6007B 2003-04 Evolution VIII Brushed Stainless Converter Replacement, Downpipe
DC MTM6007B 2003-04 Evolution VIII Brushed Stainless Turbo Manifold
DC MTT6007 2003-04 Evolution VIII Titanium Upper Front Strut Bar
DC MTT6008 2003-04 Evolution VIII Titanium Upper Rear Strut Bar
DF 00605 2 3/8" Defi-Link Boost White
DF 00606 2 3/8" Defi-Link Boost Black
DF 01905 2 1/16" Defi-Link Boost White
DF 01906 2 1/16" Defi-Link Boost Black
DF 02004 2 1/16" Defi-Link (US Ver) Oil Press Black
DF 02005 2 1/16" Defi-Link Oil Pressure White
DF 02205 2 1/16" Defi-Link Oil Temp White
DF 02304 2 1/16" Defi-Link (US Ver) Water Temp Black
DF 02305 2 1/16" Defi-Link Water Temp White
DF 02306 2 1/16" Defi-Link Water Temp Black
DF 02403 2 1/16" Defi-Link (US Ver) Exhaust Temp White
DF 02405 2 1/16" Defi-Link Exhaust Temp White
DF 02406 2 1/16" Defi-Link Exhaust Temp Black
DF 03206 VSD Basis
DF 03903 2 1/16" Defi-Gauge Temp (White)
DF 04003 2 1/16" Defi-Gauge Exhaust Temp (White)
DF 04103 2 1/16" Defi Gauge A/F Ratio White
DF 04104 2 1/16" Defi Gauge A/F Ratio Black
DF 04402 2 3/8" BF Series Defi-Link Oil Pressure Amber
DF 04403 2 3/8" BF Series Defi-Link Oil Pressure White Imperial
DF 04501 2 3/8" BF Series Defi-Link Fuel Pressure
DF 04502 2 3/8" BF Series Defi-Link Fuel Pressure Amber
DF 04601 2 3/8" BF Series Defi-Link Oil Temp
DF 04702 2 3/8" BF Series Defi-Link Water Temp Amber
DF 04703 2 3/8" BF Series Defi-Link Water Temp White Imperial
DF 04803 2 3/8" BF Series Defi-Link Exhaust Temp White Imperial
DF PDF00713SS Oil Pressure Sensor Set
ESPELIR E558C Espelir 70mm Evo Down Pipe
FID 961994 Cam Gear - 90-99 Eclipse Turbo/ 03+ Evo 8
GIALLA Evo FBDC Mitsubishi Evo VIII Front Bumper with Carbon Ducts
GRE 11501662 Type RS Blow Off Valve
GRE 11531111 Type RS Blow Off Valve Kit Evolution
GRE 11900451 Aluminum BOV Flange
GRE 13500509 Universal Oil Catch Can 9mm
GRE 13500515 Universal Oil Catch Can 15mm
GRE 13534500 2003-05 Evolution VIII Extreme Timing Belt
GRE 13534501 2003> Evolution VIII Balance Shaft Belt
GRE 15500211 Profec B Type S, Black
GRE 15500501 E-Manage Ultimate, Support Tool Included
GRE 15901500 E-Manage Ultimate Harness Set
GRE 15930013 2003-05 Mitsubishi Evo8 Turbo Timer Harness
GRE 16000211 60mm Mechanical Boost Gauge - White
GRE 16000801 60mm Boost Gauge with Peak Hold & Warning, White
GRE 16000802 60mm Electronic Boost Gauge w/ Peak Hold and Warning - Black
GRE 16000803 60mm Electronic EGT Gauge w/ Peak hold and Warning - White
GRE 16000805 60mm Electronic Oil Pressure Gauge w/ Peak Hold and Warning -
White
GRE 16000806 60mm Electronic Oil Pressure Gauge w/ Peak Hold and Warning - Black
GRE 16000809 60mm Electronic Fuel Pressure Gauge w/ Peak Hold and Warning - White
GRE 16000812 60mm Air Fuel Ratio Blk
GRE 16001001 52mm Electronic Boost Gauge - White
GRE 16001003 52mm Electronic EGT Gauge - White
GRE 16001201 60mm Electronic Boost Gauge - White
GRE 16001202 60mm Electronic Boost Gauge - Black
GRE 16001203 60mm Electronic EGT Gauge - White
GRE 16001204 60mm Electronic EGT Gauge - Black
GRE 16001205 60mm Electronic Oil Pressure Gauge - White
GRE 16001209 60mm Electronic Fuel Pressure Gauge - White
GRE 16001210 60mm Electronic Fuel Pressure Gauge - Black
GRE 16400060 Boost Pressure Replacement Sensor
GRE 16401301 3.0Kg/Cm2 Pressure Sensor
GRE 16401406 e-Manage, Pressure Sensor Harness
HAL ESBSTCNTLR ES Boost Controller
HWK 453F585 2003> Evolution VIII Hawk HPS Brake Pads Front
HWK 180F560 2003> Evolution VIII Hawk HPS Brake Pads Rear
HKS 14007-AM003 2003-05 EVO (CT9A) Fuel Rail Kit
HKS 22002-AM003 Camshaft Evo 7/8 272 Intake
HKS 22002-AM004 Camshaft Evo 7/8 272 Exhaust
HKS 31012-BM001 2003> Mitsubishi Evo Carbon Ti Exhaust
HKS 41001-BK001 Turbo Timer Type 0 Black (US)
HKS 4101-EX001 Turbo Timer Type 1 Black (US)
HKS 4101-RA009 Turbo Timer Type 0 Silver
HKS 4101-RA011 Turbo Timer Type 1 Silver
HKS 4605-RM001 EIDS Type K
HKS 80040-XM001 2003> Mitsubishi Evo Hipermax RS Suspension
HKS Evo CEPS Mitsubishi Evo VIII Kansai Service Carbon Engine Panel Set
INNOVATE 3781 Standalone Gauge Kit 16 In 1
INO 22T300-0000 3.00" T Bolt Clamp
INO 25S452-2500 2.50" 45 Degrees Silicone Elbow, Blue
INO 25S901-2000 2.00" 90 Degrees Silicone Elbow, Black
INO 25S901-2500 2.50" 90 Degrees Silicone Elbow, Black
INO 25S902-2000 2.00" 90 Degrees Silicone Elbow, Blue
INO 25S902-3000 3.00" 90 Degrees Silicone Elbow, Blue
INO 25S902-4000 Silicone Connector 4.00" Dia. x 3.00" Length, Blue
INO 25SB31-1700 Silicone Hose 1.75", 3' Black
INO 25SC01-2000 2.00" 3" Silicone Hose Connector, Black
INO 25SC01-3000 3.00" 3" Silicone Hose Connector, Black
INO 25SC01-3500 3.50" 3" Silicone Hose Connector, Black
INO 25SC01-4000 4.00" 3" Silicone Hose Connector, Black
INO 25SC02-2000 2.00" 3" Silicone Hose Connector, Blue
INO 25SC02-2500 2.50" 3" Silicone Hose Connector, Blue
INO 25SC02-3000 3.00" 3" Silicone Hose Connector, Blue
INO 25SC02-4000 4.00" 3" Silicone Hose Connector, Blue
INO 25SH01-2500 2.50" 3" Silicone Hump Hose Connector, Black
INO 25SH01-3000 3.00" 3" Silicone Hump Hose Connector, Black
INO 25SH02-2500 2.50" 3" Silicone Hump Hose Connector, Blue
INO 25SH02-2700 2.75" 3" Silicone Hump Hose Connector, Blue
INO 25SH02-3000 3.00" 3" Silicone Hump Hose Connector, Blue
INO 25ST02-2530 2.50" to 3.0" Silicone Transition, Blue
INV HS03ML8TOL 2003> Evolution VIII 02 Housing
JIC CT9AFP-SU Mitsubishi Evo 7/8 CT9A Front Pipe
LUM GL-9006-8 HID Conversion Kit 9006/6K
MUT 31866C Muteki Lug Nuts 12x1.50 Chrome Open
NRG SRK-100R NRG Quick Release Kit - Silver/Red
NX 20923-10 Import EFI Kit with 10lb bottle
NX 15963-PDA NX Digital Maximizer Var Cntrlr
PERRIN PEP-INR-200 Mitsubishi EVO VIII Short Shifter
PE AI-M723 2003-05 Mistubishi Evo8 Air Impulse
PRN EVO8HKSRINT 2003> Mitsubishi Evo8 HKS Replica Intake
RMR EV011 Mitsubishi Evo VIII Intake System
RMR EV016 Mitsubishi Evo VIII Induction Pipe Kit
RMR EV021 Mitsubishi Evo VIII Lower Tie Bar
RPS MS-16001-ST Evolution VIII Max 2900lb, Torque 500, Pressure 33%
SPE EVO CFE Mitsubishi EVO VIII SP Engineering Cooling Plate
SUN EXP0001B Hyper Force 4 Cylinder
SUN EXP40704 Hyper Force Evolution VIII Plug And Play Harness
TAN T60072 03-up Lancer Evo8 Ultra Medalion Exhaust
TOMEI BOV EVO 2003-Up Evolution Recirc BOV
ULtimate Racing EVOTP Evolution VIII Test Pipe
UNO 040900802 03-04 Mitsubishi Evo VIII Underdrive Pulley Set Polished
UNO 040900803 03-04 Mitsubishi Evo VIII Underdrive Pulley Set Red
UNO 020910801 03-04 Mitsubishi Evo VIII Crank Pulley Black
UNO 020910802 03-04 Mitsubishi Evo VIII Crank Pulley Polished
UNO 020910803 03-04 Mitsubishi Evo VIII Crank Pulley Red
WAL GSS342 In Tank Fuel Pump 255lph
bezels, pin guides
DF 03206 VSD Basis
White
pm me prices on
BRI M020FO 2000> Mitsubishi Evo 7/8 Seat Rail Left Full Bucket. that's a driver right? what else is needed to mount a seat?
thanks
thanks
I bought the DC Ti strut braces from Marty. Absolutely awesome service. Shipped them same day and I had them a day earlier than he estimated - not to mention the price was incredible. People, if there is anything you have been holding out to buy for your Evo that is on this list... do it now! You will not get pricing like this again.
