MIVEC tuning
Old Jul 8, 2006, 10:06 PM
Girlie's Avatar
MIVEC tuning
So has any IX owners tuned thier MIVEC mapping yet? I know some of the tuners here do adjust it, but I doubt they are going to divuldge any of the secrets. Just would like to get some information on it, as some tuners feel alot of power can be made via MIVEC map adjustment.
Anyone with info they would like to share?
Girlie
Old Jul 8, 2006, 10:12 PM
EFIxMR's Avatar
I tuned our shop EVO9 RS and made 291 wtq 288 whp on a Mustang dyno that reads similarily to Buschurs.
We had to end our session early as we didn't have enough time. Tuning the MIVEC is really difficult, one of the most difficult cars I've tuned ever. And my experiences dates back from 98' when I first started.
mods are
Turboback exhaust (tanabe 2.75 dp, custom Speedelement 3" test pipe, Garage HRS exhaust), HKS drop in filter, Hallman boost controller.
Old Jul 8, 2006, 10:41 PM
Girlie's Avatar
mods are
Care to share any pointers on it, without giving away too much?
Like what are the maximum values you could use safely, and what the numbers show in the map cells relate too? Basically some starting points on the MIVEC map and such.
Thanks!
Girlie
Old Jul 9, 2006, 01:33 AM
jcsbanks's Avatar
http://john824.fotopic.net/p30707600.html
This was my first shot educated guess based on previous fiddling with VVTs, info from Vishnu and another tuner. I gather that some take it to 28.8 degrees. It appears that I'm hitting 14.5 PSI at 2300 RPM now which is a small improvement, perhaps 100-200 RPM.
Old Jul 9, 2006, 09:02 AM
gunzo's Avatar
hi I take it that the lower map is stock and teh upper map is redone??
wanna take a look at mine STOCK??? its way off and much higher than what you have ..
Old Jul 9, 2006, 10:18 AM
jcsbanks's Avatar
Please show us Which ECU?
Old Jul 9, 2006, 12:36 PM
f-dub's Avatar
http://www.billzilla.org/engvariable.html
Old Jul 9, 2006, 01:47 PM
Girlie's Avatar
Thanks John. Which map (top or bottom) is the modded one? Both of them are different from my USDM stock map and tuned map.
Girlie
Old Jul 9, 2006, 02:21 PM
jcsbanks's Avatar
Top is modified, bottom is JDM stock.
I didn't see the reason for retarding it again after they advanced it so I advanced it in a large early midrange block where I hit peak boost and make lots of torque. The changes seem to spool up the turbo slightly earlier along with richer fuelling it feels torquier. Change of boost has a much larger effect though.
Old Jul 9, 2006, 06:07 PM
gunzo's Avatar
Here you go john !
This is from a JDM Evo 9 RS totally stock ..
have fun matching it ! Let me know what's the difference ..
Hey if you have any other info .. please let us know
Old Jul 10, 2006, 01:05 AM
JohnBradley's Avatar
I have only been focusing on the upper reaches of the map at first, but above 6000 the 0* portion of that map (100-300 load cells) definitely benefits from more timing. Deadspot is almost gone above 6000-7000 range.
Old Jul 10, 2006, 01:19 AM
jcsbanks's Avatar
Thanks gunzo, will have a play
Old Jul 10, 2006, 11:16 AM
jcsbanks's Avatar
Hi gunzo, do you have any timing and fuelling maps, or even the ROM from a 9 RS?
Old Jul 11, 2006, 05:18 PM
nvr2fast's Avatar
I would be curious if anyone has the Ralliart JDM Evo IX map? Would the map be similar to the JDM Evo IX RS version?
Old Jul 11, 2006, 08:02 PM
andenbre's Avatar
What I have noticed is that the map goes in steps of 4.8. 1st things first are we sure that this # translates directly into degrees of advance/retard? 28 degrees seems like alot of range.
Quick Reply: MIVEC tuning
