Who's who and what and where...
Old Dec 8, 2005, 09:51 AM
Richard L's Avatar
********** Updated: 23rd February 2014 **********
It is a good time to do a complete listing of current water/alky injection manufacturers and their product. Specifications, capabilities and price range. It is a copy post from EVOM a few months ago and have proved to be useful to most potential WIA users.
I will start and fill-in more manufacturers as more information is available:
Activeautowerke
Capabilities: Adjustable manifold pressure activation
Pump: Shurflo
Electronic Controller option:: No details
Chemical compatibility: Water, Alcohol
Failsafe: not mentioned on site
Price range: US$1200.00
Warranty: Not mentioned on site
URL: http://activeautowerke.com/cooling/main.php
EMAIL: aatuning@activeautowerke.com
AEM
Capabilities: Progressive delivery proportional to IDC/MAP sensor.
Pump: Aquatec with by-pass USA
Electronic Controller::Based on pump speed to vary pressure/ flow.
Chemical compatibility: Water, methanol
Failsafe: Turbine Flow sensor based as an option from US$277.
Price range: US$422-450
Warranty: 1 year unconditional and 100% methanol URL: http://www.aemelectronics.com/water-...ction-kits-23/
EMAIL: emstech@aemelectronics.com
AIS
Capabilities: Progressive delivery proportional to manifold pressure and any 0-5V signal.
Electronic Controller:: Based on pump speed to vary pressure/ flow.
Failsafe: No option on site.
Price range: US$468.99-659.00
Warranty: 1 year unconditional and 100% methanol URL: http://www.alcoholinjectionsystems.com/index.html/
PHONE: 1-801-447-2559
Alkycontrol
Capabilities: Progressive delivery proportional to MAP sensor. Inline filter, metal fittings, and stainless steel braided lines.
Pump: Shurflo
Electronic Controller::Based on PAC module controlling pump speed to vary pressure
Failsafe: Failsafe Bi-colored LED works of pressure sensing, inline filter, metal fittings, and stainless steel braided lines.
Price range: from: US$425-495
Warranty: 1 year unconditional and 100% methanol URL: http://www.alkycontrol.com/
Online form or phone
Aquamist
Capabilities: PWM inline valve and electronic controller
Pump: 160psi by-pass Aquatec pump
Chemical compatibility: Water, Methanol. 100% methanol.
Failsafe: Turbine flow sensor- full time monitoring with in- dash gauge. boost drop and map switching output.
Price range: US$550-850.
Warranty: 12 months
URL: www.aquamist-direct.com
EMAIL: richard@aquamist.co.uk (sales enquiry), richard@aquamist.co.uk (technical)
Aquastealth
Capabilities: Static flow, Pressure switch activated inline solenoid.
Pump: Shurflo
Chemical compatibility: Water and Methanol.
Failsafe: unspecified
Price range: US$199.00
URL: www.aquastealth.com
EMAIL: sales@aquastealth.com
Coolingmist
Capabilities: Progressive, Static flow – single or dual stage
Electronic Controller: Digital Programmable "progressive" style controller capable. Pump speed based.
Pump: Aquatec USA
Chemical compatibility: Water, 100% Methanol.
Failsafe:: Pump current monitoring - no flow sensor option.
Price range: US$270 to $899.95
Warranty: 1 Year Warranty
URL: www.coolingmist.com
EMAIL: coolingmist@comcast.net
Devilsown
Capabilities: Static flow, PWM pump speed control option
Electronic controller option: 0-5v (selectable scales 2 bar,3 bar,voltage) – pump speed based system.
Pump: Custom Aquatec USA
Chemical compatibility: Water, 100% Methanol safe (EPDM Seals)
Failsafe: None.
Price range: US$380-460
Warranty: One Year Limited
www.alcohol-injection.com
EMAIL: sales@.alcohol-injection.com (sales inquiry), support@alcohol-injection.com (technical)
Hydramist by Element Tuning
(Work with Hydra EMS only)
Capabilities: Full 3D hi-res mappable, inbuilt failsafe.
Electronic controller: Element Hydra stand-alone EMS.
Pump: Shurflo (150W), with 160psi internal by-pass
Chemical compatibility: Water, Methanol, Ethanol, Iso-propyl
Failsafe: DDS3 flow sensing system - auto map switching via DDS3 v7.
Price range: US$799.00 not including Hydra EMS
Warranty: Not yet specified
EMAIL: phil@elementtuning.com
URL: www.elementtuning.com
RSR
Capabilities: Static flow, Port injection
Pump: Shurflo
Failsafe: water level switch
Price range: US$745.00-795.00
Warranty: call
URL: www.rbracing-rsr.com/waterinjection.html
Snow Performance
Capabilities: Static flow, solenoid
Electronic controller option: Progressive pump speed controller +$129.00
Pump: Shurflo
Failsafe: turbine flow sensor- boost bypass, map switch.
Price range: US$604 - 803 (IDC/MAP/MAF vs Pump speed)
Warranty: limited option by vendor
URL: http://snowperformance.net
EMAIL: sales@snowperformance.net
This is by far the most comprehensive research I have done for a long time. I will continue to update. Adding more manufacturers.
Old Dec 8, 2005, 09:54 AM
dryad001's Avatar
Wow what a great idea, this has got to be stickied.
What about Buschur, AMS...
Old Dec 8, 2005, 09:58 AM
Richard L's Avatar
Please send information,
I will update it - I believe SMC made some of them? Please confirm.
I need all your help to compile the entire list. It may looked biased since I have put Aquamist on the top - unless I call ourselves Zquamist.
Richard
Old Dec 8, 2005, 10:22 AM
Richard L's Avatar
I have just visited AMS and Buschur website and none are listing water/alky injection kit.
I am only listing manufacturers and not product re-labelled resellers.
Richard
Old Dec 8, 2005, 11:55 AM
SlowCar's Avatar
Aquamist is COOLER
Old Dec 8, 2005, 07:44 PM
TTP Engineering's Avatar
Not off to a good start... TTP-Engineering does not sell Snow Performance kits. You did not request this information from us and your misinformation is slanderous. This thread should be deleted if the information cannot be kept factual. We are located in Orlando, FL which is no where near Calardo or Colorado.
Where is the Truth Squad when you need them? LOL
TTP Engineering
Capabilities: Static flow, Progressive controller –sold separately(PWM pump)
Pump: Shurflo Based
Control option: pressure switch, TPS or MAP (0-5v selectable)
Failsafe: Not mentioned
Price range: US$399.00
Electronic Controller: not mentioned on site
Warranty: not mentioned on site
URL: http://www.ttp-engineering.com
EMAIL: online form filling
I will update the list as more information becomes available. Please post on this thread if you have found any incorrect information – use the above information at your own risk.
Richard L
Old Dec 8, 2005, 08:02 PM
SlowCar's Avatar
hmmm......did you have some bad food for dinner? The nice dude is trying to summarize what is available out there...........and all i can see is the location is entered wrong...and you are all bent out of shape....slanderous?
Originally Posted by TTP Engineering
Not off to a good start... TTP-Engineering does not sell Snow Performance kits. You did not request this information from us and your misinformation is slanderous. This thread should be deleted if the information cannot be kept factual. We are located in Orlando, FL which is no where near Colorado.
Old Dec 8, 2005, 08:03 PM
Ultimate CC's Avatar
Buschur uses SMC and AMS uses alkycontrol
SlowCar's Avatar
had to dig this one out from a past post, barb fittings and vinyl hose.........any idea how it works?
http://www.aquatune.com/index.asp
Old Dec 8, 2005, 08:05 PM
Admin Emeritus
Speedlimit's Avatar
TTP Engineering:
I don't understand your point. Why is it slanderous? Or vendor bashing? He ask for comments which you have given him. He made a mistake and I assume will fix it. If he doesn't, I'll remove it.
Speedlimit...
Old Dec 8, 2005, 08:19 PM
gofaster87's Avatar
No wonder the English think we are jackasses. Richard L has been the most helpful person I know in the water injection arena going as far as sending me parts from England free of charge. This truth squad BS is getting out of hand, everytime something happens on this forum somebody brings up that bull*hit. Shame on you Tom(smogrunner) for starting this crap. Funny he knows better than to try to start something like this on SoCal Evo.
Originally Posted by Speedlimit
TTP Engineering:
Speedlimit...
I am certain Snow Performance would not like our company name paired with their address and location. Likewise, we do not sell their products and do not want to be associated with them. Everything from the location to company to the pricing is incorrect.
Old Dec 8, 2005, 08:27 PM
SlowCar's Avatar
at least...this is more civilised......just PM Richard or write the correct info here and it will be corrected once he sees it
Old Dec 9, 2005, 01:00 AM
fromWRXtoEVO's Avatar
How about AMS alcohol kit?and how about the fancy water system from Works?
Quick Reply: Who's who and what and where...
