MY OZ Rally in "Rally Trim"
Old Nov 28, 2005, 07:40 PM
LancerPhoenix's Avatar
Here are some pics take on our hour break between stages in the Pine Barrens Rally (TSD Rally). Also some pics of the light bar with a pair of HELLA Rallye FF 1000's mounted to it. The bar is acually designed to be used on a SUV/Truck. But since it uses the existing licence plate holes it worked well so I didn't have to drill extra holes in my bumper. It's held on by 2 8" bolts that go thru the bumper and all the way through the crash bar. I think I've captured the "rally look" I was going for in a tasteful way!
Attached Thumbnails MY OZ Rally in "Rally Trim"-547619-r1-19-23a_edited.jpg   MY OZ Rally in "Rally Trim"-547619-r1-20-24a_edited.jpg   MY OZ Rally in "Rally Trim"-547619-r1-18-22a_edited.jpg   MY OZ Rally in "Rally Trim"-547619-r1-08-8a_edited.jpg   MY OZ Rally in "Rally Trim"-547619-r1-03-2a_edited.jpg
Old Nov 28, 2005, 07:44 PM
ambystom01's Avatar
Pics don't work.
Old Nov 28, 2005, 07:47 PM
Walkingchaos's Avatar
fix the pics i wanna see this
Old Nov 28, 2005, 07:51 PM
1sweetoz's Avatar
pics ain't workin
Old Nov 28, 2005, 07:57 PM
Think I fixed
Old Nov 28, 2005, 09:20 PM
05ES's Avatar
looks good. lots of light
Old Nov 29, 2005, 04:37 AM
Thanks! Well we didn't finish the rally till about 9-10ish and your out in the middle of nowhere, so having alot of light was very helpful. Turned night into day!
Old Nov 29, 2005, 06:19 AM
*bumpy*
Old Nov 29, 2005, 06:53 AM
Kurt's Avatar
Nice look. What place did you finish in?
Old Nov 29, 2005, 07:34 AM
wudbevo's Avatar
i want to rally! wish we had somewhere around here to do it....
Old Nov 29, 2005, 07:53 AM
blaze_125's Avatar
what kind of beam are your lights?
Old Nov 29, 2005, 08:34 AM
We finished 27th overall out of 58 and 13th in our class. It was our first one, we weren't really tring. The beam is called Free Form. Thanks for the comments!
Old Nov 29, 2005, 08:39 AM
blaze_125's Avatar
free form beam? is it more like a pencil beam or more of a wide beam?
Old Nov 29, 2005, 09:57 AM
The newest lamp in the Hella lineup, the Hella FF1000. Similar in size to the popular Rallye1000, the computer designed Free Form Reflector results in more output than any other 55w lamp in its class and a precisely shaped beam pattern that wastes less light. The lens is clear tempered glass and the reflector is cast magnesium. The ABS shell on the back is essentially a dust cover as the base fastens to the magnesium reflector - which provides the structure of the lamp. Once bolted to a horizontal surface, adjustment is by the single knob on the back. Once aimed where you want, tighten the knob with a 6mm hex wrench. This is an ultra-light, high performance auxiliary lamp.
A city light is similar to a day time running light. They are required in Europe's biggest cities where the street lighting is excellent and headlamps are not allowed to be on, even at night. It is a 5watt bulb in the reflector which lights up the reflector, but provides no additional illumination on the road.
Lamp Kits include 2 Lamps, wiring harness, fuse, relay, switch, 2 Black on White Vinyl Stone Shields and mounting hardware.
Here is the link where I got them.....They are on sale! http://www.rallylights.com/hella/ff1000.asp
Old Nov 29, 2005, 10:10 AM
gregivq's Avatar
You sure know your lamps. Looks pretty cool.
Quick Reply: MY OZ Rally in "Rally Trim"
