MPS_UTEClogger 2.3
MPS_UTEClogger 2.3
I have been in contact with Jason (the designer of this program), and he has finally done it!!!!
This new logger, that was previously only available for subie owners, is now compatable with evo owners. Check out the site:
http://mpsav.com/MPSUTECLogger/MPS_U...r_Download.htm
He said that he is currently trying to get an account activated to share his knowledge on this, so be patient on answers to questions. I am going to e-mail him this thread so he can know where this has been posted. Can't wait to give this a go.
hrm, interesting, glad i saw this before i installed. I've had the innovate standalone gauge chillin for a while, just recieved my utec yesterday, with tuna, simply for wideband, since i couldn't load the other data ( can't load anything, nothings installed )
But i guess i'll install the innovate and just the utec right now, run this, see how it works.
subscribed for updates.
Hey guys, my account is finally active, and I'm glad to see you are all interested in the program. Since I don't own an Evo, I am relying on all your feedback to make sure that everything is working good with the new Evo feature. If any of you have problems, please email me about them. The best place to send email is located in the Help menu of the program, which is UTECLogger@mpsav.com . Please feel free to report any bugs, or suggestions for improvements.
Yes it will. The program is compatible with the LM-1, LC-1, AEM, and Tuner wideband products. The TechEdge2.0 will be added soon to the list as well. The Tuner suppprt is still in beta, as there were connection problems in the last version that I'm not sure are resoved yet. Also, the program DOES NOT support "Linking" of any kind, meaning the Tuner has to be on a seperate Com port than the UTEC, they can't be linked. This might seem like a pain, but the goal is to able to add different ECU's and WB and let them all work with each other. This is true of the LC-1 product as well, only 1 LC-1 can be connected at a time, even though the LC-1 technically supports multiple Innovate products linked together.
-jason
What I want to know is is you use the UEGO wideband w/gauge, will this program still work?
-jason
So far i dont like the program...The only thing that works is the logmapping. So far this thing sucks.
You need to remember that this works on WRX's and STi's just fine, and that I DON'T OWN A EVO to debug on. If you don't like that not everything works, why didn't you record a log using the program and send it to the feedback email. Why don't you describe a little better what the actual problems are? I'm all for fixing the errors/bugs/glitches when they arrise, but "this program sucks!" sure doesn't help me fix anything. If anything, it makes we want to say "well go back to the program that you were using before to do all this..." oh yeah, there isn't one! Be nice or shut the h**l up.
Now, if ANYONE ELSE is having the same problems, I would be happy to look at the logs its producing and try to fix any errors that are happening.
-jason
Are you going to make it complatable with PLX Widebands? I have the R-500.
How popular are the PLX units? If there are enough people using them, and the information for serial protocol is available, I can look into it. It probably wouldn't happen REAL soon, but can be added to my ever-growing list of To-Do's.
-jason
I can send you a few logs if you need them.. all have the AFR appended to the end of the file just like the UTEC/Tuner in series would do..
I would like to suggest that you possibly can use that last column for AFR if its there instead of requiring the Tuner to be on another serial port.. But thats just me..
Originally Posted by jmussetter
Well thanks for positive attitude toward me trying to help. Maybe you would rather drive your Evo All the way to the Bay Area, CA and let me debug the program on your car in person, so that when you leave everything works great!
-jason
-jason
Sorry didn't really mean to come off like that. Here is what happened. I tried to log a run and somehow it didn't save it or either im an idiot and cant find the file. I'll go back to the car in a little bit and try and get a saved log. On the view gauges menu when the "screen" pops up it doesn't seem to read in real time, but if I look at the real time line everything is correct. Not that I need another dashboard, but its a quick reference while driving.
One more thing, can I save the file as a .txt file and then still use it as a log mapper for future reference?
Alright heres the deal. First off the log mapper or map logger whatever you want to call it is great. But the thing is once you close out the log file this option is no longer available. This would be an awsome tool to go back and forth between tps, maf, afr, etc. But in the timing log everything is logged up in negative values, but in the main log it's in positive??? This has me just a little confused.
1. Make sure "Evo8 UTEC" is selected under "ECU Type".
2. Make sure you have the correct type of WB02 selected under "WB02 Type"
3. Make sure the car is on and UTEC and WB are powered up
4. Click the Connect button and you should see data in the "realtime UTEC log" window
5. At this point if you want to SAVE A LOG from to your harddrive, then at the bottom of the window, click "browse" to give the files a name, and click OK. NOTE: It is NOT saving any data at this point...you must click on "Open Log". All data will be saved to the file now. When you want to stop saving the data to the hard-drive, click on "Close Log", and the recording will stop. You must change filename to save-as before opening another log, or it will overwrite the current log with the same filename.
6. Before turning the car off, close the current log and "disconnect" from the units.
This should get you to the point of being able to record a log and send it to me so I can see first hand what kind of data mangling might be happening...
gook luck, and I'll wait to see some logs...
BTW, has anyone else tried the program yet, and is it doing the same thing to you? Just curious...
-jason
