Endless big brake kit (6 and 4 pots blue)
Hey guys,
I have a set of Endless big brake kit for the Evo on sale for $7025 shipped or free installation if local.
SOLD!!
The RACING 6 and RACING 4 FRONT & REAR set is simply beyond belief. This is the Racing Version, ENDLESS flagship caliper used on Japan GT's ENDLESS TASAN Advan GT3R Porsche.
-Front and rear set includes Endless caliper x 4
-Endless brake pad (street or circuit compound optional) x 4
-Endless teflon-coated, stainless-steel brake lines x 4
-ZEAL Straight-6 slotted disc rotor x 4, and the necessary brackets and adaptors for fitment.
Disc Rotor Size : 370x32mm Front
Disc Rotor Size : 332x30mm
2 piece rotors
Thanks,
Tom
Gruppes
510-783-5300
SOLD!!
2 piece rotors
Thanks,
Tom
Gruppes
510-783-5300
nice set of brakes!!!!!!
anyways, just wanted to let you know that the brakes pictured could be the straight 6 front and racing 4 rear.
cal or tom @ gruppe-s, can you double check to see if this is for sure the racing 6 front and racing 4 rear.
the straight 6 front are 345mm while the racing 6 front are 370mm.
also, to buyers buying the system with the racing 6 front, there is only a limited set of wheels in 18" that can fit the racing 6 front. i will tell you now that any volk ce28/le28 will not work since endless usa measured my wheels to see if they fit the racing 6.
maybe the advan RGII, RCII, and TCII in 18" will fit the racing 6.
likely you will need to run 19" wheels to run the racing 6 front.
having sold a couple sets, the TCII works as does the RGII in 18x9
also, as a neat point of interest, the front rotor on the racing setup, even at 14 lbs, is lighter than the stock Evo rotor
