Drew WRX: Accessport vs. XEDE
Old May 5, 2005, 05:18 PM
shiv@vishnu's Avatar
Drew's WRX has a full exhaust and up-pipe. No cat.
The following are the dyno results with it running a Stg 2 Cobb Accesport ECU upgrade. One is with the ignition advance multiplier defaulted to 8 (right after ECU reset). The other higher hp graph is with the advance mulitiplier at 16 (indicating full aggressive/max positive learning). Stock cars, by comparison, usually dyno in between 160-165 depending on what the ignition advance multiplier settles to.
shiv@vishnu is offline
Old May 5, 2005, 05:26 PM
Next we took out the AP and ran the stock ECU. Below is the stock ECU compared to the Cobb AP. In both runs, the advance mutiplier is set to 16.
RED is stock ECU. Purple is Cobb AP.
Whp and Torque:
Boost and AFR:
Yes, the stock ECU made more peak hp and more low end/midrange. The Cobb ECU made more power above 6000rpm. But it also ran 4 more psi of boost at high rpm.
Old May 5, 2005, 05:31 PM
And with a custom-tuned XEDE...
Next we plugged in the XEDE (on top of the stock computer) and made more power. Just to keep things fair, I kept the boost curve nearly identical to that of the Cobb AP. Ignition advance multiplier was also set to 16.
RED is Cobb AP. PURPLE is XEDE.
WHP and Torque:
Boost and AFR:
Old May 5, 2005, 06:40 PM
ez76's Avatar
i guess the cobb motto is "let's get retarded" ?
ez76 is offline
Old May 5, 2005, 07:01 PM
DarkMastyr's Avatar
wtf, how can someone have such a shoddy aftermarket tune?
DarkMastyr is offline
Old May 6, 2005, 06:17 AM
alleggerita's Avatar
BTW on nasioc.com there is at least one report of an STI grenading big time when road racing with an accessport tune.
alleggerita is offline
Old May 6, 2005, 06:36 AM
cooter's Avatar
Shiv: make a "Tales from the dyno" post regarding Drew's car on Nasioc.
cooter is offline
Old May 6, 2005, 07:23 AM
donour's Avatar
Originally Posted by shiv@vishnu
N
Holy torque, batman! Maybe I should get an xede for my wrx as well. I had no idea that a stock wrx was capable of that much midrange.
Shiv: I've heard varying opinions. What's your estimate of the power difference (at the wheels) between the auto wrx transmission and the 5-speed?
EDIT: oh wait, did you say stage 2? So are the above numbers with the cobb 3" turboback?
d
donour is offline
Old May 6, 2005, 08:17 AM
Drews_WRX's Avatar
nice work shiv. Im at school, i'll right back later
Drews_WRX is offline
Old May 6, 2005, 03:34 PM
Borti's Avatar
This really doesn't prove a ton, as there are plenty of people out there (on Nasioc, and other Subaru forums) that dyno large gains from stock vs. Cobb Stage 1. This is 1 instance (one car with AP), and should be taken with a grain of salt (as Cobb is a direct competitor of Vishnu.)
On another note, is this XEDE a custom tune, or off the shelf map?
Good numbers out of the XEDE nonetheless.
Borti is offline
Old May 6, 2005, 06:14 PM
Dustin@Vishnu's Avatar
Four out of the four Cobb APs we've tested have made less peak power than the stock ECU. This is holding all things constant (including ignition advance multiplier). I don't think many people take this extra step when doing their A/B comparison.
Shiv
Dustin@Vishnu is offline
Old May 6, 2005, 06:21 PM
EvoM Administrator
Noize's Avatar
Awesome info. Thanks for posting!
Noize is offline
Old May 7, 2005, 01:34 AM
I'm not going to do that because it's already stirring things up enough with the resident Kool Aid drinkers. Sheesh....
shiv
Old May 7, 2005, 04:46 AM
cooter's Avatar
shiv
No doubt...stop it with the misinformation and toxic marketing ploys already!
cooter is offline
Old May 7, 2005, 06:24 AM
finnrex's Avatar
Just to let you know, it ain't the AP's fault. Yeah that car was using the AP, but I've seen an EcuTek tuned motor wave bye bye too. It ain't the tuner, if anything it'd be the motor blowing due to oil starvation.
Mika(Subaru tech)
finnrex is offline
Quick Reply: Drew WRX: Accessport vs. XEDE
