Vacuum Control Valve
I pressure tested my system tonight to see if there were any leaks, and I found the vacuum control valve leaking out of the end port. I don't have a digital camera handy just yet, but it should be pretty easy to describe where it is. First, if you look at the vacuum hose diagram on the hood, it is labeled there. Looking at the motor from the front, look just behind the fuel rail and you will see all the gold colored vacuum lines. Attached to the assembly are two solenoid valves, and the vacuum control valve. The vacuum control would be all the way to the left and would have two lines connected to it, and no electrical connectors. In any event, does anyone know if this is allowable to leak under boost?
infam0usndn2nv
Jul 21, 2015 11:32 PM
FreshEvoEight
16
Mar 8, 2015 10:05 PM
