a real newbie help!!!
Old Dec 26, 2004, 07:12 AM
ltwayner's Avatar
Hey all,
Just purchased a an 03 evo from mitu dealer already with after market part installed from the dealer ( not straight from manufactuer ). Anyway, it has a SAFC 2 on it. My friend play with it clicked on initialized all and returned it to factory setting. I've been doing research and trying to do initial setup, which i think i am successful (CEL doesn't come on anymore). The problem is everytime i am in new neutrul or press the clutch in, the car's rpm goes so low that it stalls. Also, ocasionally, I hear like a thump noise, coming under the passenger side seat....not a backfire, but seems to be coming from the converter. Anyone knows what the hell is going on? Can the SAFC 2 really caused this much problem when not setup right? Can anyone give me a base stock setting? BTW not a car tekkie, I don't even know what the SAFC 2 does..
stock turbo
Old Dec 26, 2004, 08:40 AM
kapolani's Avatar
Originally Posted by ltwayner
Hey all,
stock turbo
If I were you I'd do a lot more research before you start messin with it.
If possible, return your car to stock form, and see if it gets rid of the problems.
Eliminate one possibility at a time.
Good luck!
Old Dec 26, 2004, 12:12 PM
Deca Auto's Avatar
i don't have a safc and it used to bog. but i read somewhere the safc is suppose to prevent bogging. bogging=stalling
Old Dec 27, 2004, 09:21 AM
20psiGuy's Avatar
get professional help
Old Dec 27, 2004, 12:38 PM
turbolarry's Avatar
TURN THE ENGINE OFF!
NOW!
Do you know what size injectors are in there?
Old Dec 27, 2004, 01:16 PM
absinthe's Avatar
zero everything out see if that solves the issue.
Old Dec 27, 2004, 01:18 PM
BlazeGT4's Avatar
You really need to get that car to a respectable shop and see what's in it.
Larry is 100% right. You could have larger injectors. You could have a POS flash. You could have blinker fluid leaking into your cat. The point is, you just don't know with a modded car.
Find a good local shop. Limp the thing in there or have it towed. But get it taken car of before you lean the thing out and do some real damage.
Blaze
Old Dec 27, 2004, 01:27 PM
bovbilly's Avatar
Bbbbbbbbbbbbbbbooooooooooooooommmmmmmmmmmmmmmm!!!! !!!!!!!!!!!!!!!!!!!!!!
What The **** Just Blew Up!!!!
Nevermind, That Was My Muffler Bearing!
Old Dec 27, 2004, 01:29 PM
JohnnyTwoThumbs's Avatar
Lesson #1
NEVER let your friends **** with your car, especially friends who have no idea what they are doing.
Old Dec 27, 2004, 01:39 PM
ultraflip's Avatar
next up... **parting out blown evo engine**
Old Dec 27, 2004, 09:53 PM
jansolo's Avatar
I've seen some people blow their spark plug coolant levels with improper tuning. You really need to be careful with an SAFC II, but not an SAFC I - those things couldn't hurt a fly.
Old Dec 28, 2004, 01:35 PM
w8less1der's Avatar
silverEVO8
Oct 23, 2006 03:02 AM
grico42
16
Aug 15, 2006 06:09 PM
NITROHEAD
Lancer Aftermarket Forced Induction Tech
Jul 12, 2004 02:32 PM
DeZaVu
Oct 7, 2003 03:02 PM
Jrod@Buschur
Sep 11, 2003 01:44 PM
Quick Reply: a real newbie help!!!
