Oct 24, 2009, 08:56 AM
Personal Sales Rating: ( 61)
Drives: Evo 8
Thanks to Indy Evo!!! (Wilson D Fuel Rail)
Offline
Oct 25, 2009, 01:13 AM
Drives: Evo 8
Switching to Wilson Fuel Rail from stock rails made my Inj duty cycle jumped from 93% to 84% @30psi boost without touching anything in my AEM.
Offline
Nov 1, 2009, 09:52 AM
Personal Sales Rating: ( 2)
Drives: 06 IX SE Apex Silver
How does a larger rail affect the duty cycle?
__________________
Spoolinup COP
www.spoolinup.com
Online
Nov 2, 2009, 03:05 PM
Personal Sales Rating: ( 33)
Drives: Evo IX MR
Does the stock fuel return hardline bolt up or does it have to be ditched for a piece of rubber line?
__________________
Works drop-in :: AMS LICP :: English Racing ported EM and HS :: Titek v2 O2 :: Helix v2 DP :: MIL.SPEC 100 cps cat :: RRE Stealth Stainless :: Walbro :: FIC 1050s :: E85 :: self-tuned :: 26.5 psi :: 340wtq/375whp VDR 5.71 EvoM mode, 77°F
Offline
Nov 3, 2009, 02:47 AM
Personal Sales Rating: ( 4)
Drives: Evolution 9 SE
I ordered one a couple of days ago can't wait for it to show up!
Online
Nov 3, 2009, 05:37 PM
Quote:
anyone?
__________________
Spoolinup COP
www.spoolinup.com
Online
Nov 3, 2009, 05:49 PM
Personal Sales Rating: ( 18)
Drives: GG Evo 9 Gsr
Quote:
He basically answered your question already..
Offline
Nov 3, 2009, 05:54 PM
Drives: Evo IX MR
The idea is that a larger plenum volume helps to equalize the fuel pressure reaching each injector. If his IDCs went down, that likely means that the cylinders feed at the end of the fuel rail were not seeing as much fuel pressure as the cylinders closer to the fuel rail entrance. I suppose its also possible that the small inlet diameter of the stock rail may be been causing some turbulence in the rail or acting a flow restriction. However, I think the inlet diameter is the same as the diameter of the hardline that plugs into the rail.
__________________
Offline
Nov 3, 2009, 06:00 PM
Personal Sales Rating: ( 1)
Drives: 2006 EVO RS & 2003 F150 SCREW
Quote:
Good ?
I know there was a thread about it but not sure if it was mentioned
Offline
Nov 3, 2009, 06:33 PM
Personal Sales Rating: ( 0)
Drives: 1 Gen
i will be installing one on sat and will post pic after
__________________
I BUILD IT - I TUNE IT - I RACE IT - I DRIVE IT - MORALES RACING....STILL THE FASTEST 13G DSM
Offline
Nov 3, 2009, 06:43 PM
Drives: Evo 8
bolt right up
Offline
Nov 3, 2009, 06:50 PM
thanks that was what I was after
__________________
Spoolinup COP
www.spoolinup.com
Online
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
