Quote:
Originally Posted by bluebyu36
dam thats pretty cool im going to try it thanks for the info, i have a built motor for about 4,000 now...what are some bad thing they could find???
Elements are quantified in the oil at part per million levels (PPM). This list shows the most common sources of the elements in a gasoline or diesel engine oil.
Aluminum: Pistons, bearings, cases (heads & blocks).
Chromium: Rings, a trace element in steel.
Iron: Cylinders, rotating shafts, the valve train, and any steel part sharing the oil.
Copper : Brass or bronze parts, copper bushings, bearings, oil coolers, also an additive in some gasoline engine oils.
Lead: Bearings.
Tin : Bearings, bronze parts, piston coatings.
Molybdenum: Anti-wear additive, coating on some new rings
(washes off as break-in occurs).
Nickel : Trace element in steel.
Manganese: Trace element, additive in gasoline.
Silver: Trace element.
Titanium: Trace element.
Potassium: Antifreeze inhibitor, additive in some oil types.
Boron: Detergent/dispersant additive, antifreeze inhibitors.
Silicon : Airborne dirt, sealers, gaskets, antifreeze inhibitors.
Sodium: Antifreeze inhibitors, additive in some gasoline engine oils.
Calcium : Detergent/dispersant additive.
Magnesium: Detergent/dispersant additive.
Phosphorus: Anti-wear additive.
Zinc : Anti-wear additive.
Barium: Detergent/dispersant additive.
Physical properties: Viscosity, flashpoint, % fuel and antifreeze, % water and insolubles are all measured in gasoline and diesel engine oils. If fuel is present in the oil, the viscosity and flashpoint will often be lower than what was stated in the "Should be" line. Insolubles are solid material that is centrifuged out of the oil. They are typically free carbon from the oxidation of the oil itself, along with blow-by past the rings.
Taken right from the "Service" tab on
blackstone-labs
As you can see bearings attribute to a variety of metals. If I had a built motor I would do this test once every other oil change just to make sure everything is running and maintaining correctly.
