FS: NYC/Long Island Built 2.4 Long block, Tranny, T-case, 6266, AEM EMS, Manifolds
Feel free to PM me with any questions. If you would rather talk by text or phone, PM me your phone#.
ATTN MODS: I cannot take a pic of the VIN# on the tranny since the bell housing was replaced with a new OEM one that doesnt have a VIN#, also the engine block was machined/blasted so the VIN# is not visible. The block is from a 2001 Eclipse GS 4G64 and was purchased from Islip Auto Recycling back in 2006.
All prices are plus shipping and paypal. I cannot ship the engine.
Engine, Tranny, T-case, Clutch and Axles are still in the car and will be removed once a deposit is received.
All parts are off my custom built 99' Galant which has a complete EVO 8 power train in it. All parts are exactly as they would be installed on an except the motor which will require an Evo water pump and spacer, since I used my Galant pump in order to use my galant p/s pump and a/c compressor since it uses 2 belts instead of a serp. belt like the Evo.
Built 2.4 Long Block, Includes head, block, oil pan, oil pump, water pump, and
cam gears. Does not include JDM Evo 7 valve cover. You must use a stock Evo 8 water pump and the appropriate spacer for the pump. Approx 5k miles on the motor, comp test 195-205 across the board
Engine $4500 OBO, Local pick up only in Long Island, NY
OEM 4G64 Block, bored .020 over, align honed, magnafluxed prior to assembly
OEM 4G64 crank, polished
Eagle Rods
Wiseco pistons 9.5:1
King Race bearings
ARP Rod bolts, Main studs and Head studs
Balance shaft eliminator
Oil pan has -10 AN welded on
Cometic head gasket
Evo 8 head (unported)
+1mm Supertech Valves
Crower Springs & retainers (old school style before BC came about)
GSC S2 cams
Fidanza cam gears
OEM Mitsu timing belt and components
Tranny $2750 shipped or $2600 picked up in Long Island NY or Plus Shipping/Paypal
3500 miles since rebuild
Built Evo 8 5-speed trans
Built by DogBoxRacing several years ago
replaced 1st gear and 3rd gear
4.11 Final drive upgrade
PPG Billet output tube upgrade
brand new oem bell housing (old one had crack at transfer case mounting)
REM ISF processing on internals
T-Case SOLD
200 Miles since rebuild
Built Evo 8 non-acd t-case by Jacks Transmission
New OEM Ring & Pinion
10MM bolt upgrade
WaveTrac LSD
Clutch $600 shipped/paypal'd FIRM
Competition Clutch Twin-disc (option C)
200 miles on it
Inclds slave cylinder conversion and TOB
Turbo ---- SOLD
Under 200 miles
Precision 6266 CEA DBB air cooled
T3 .82 A/R 4-bolt hotside, Shaved/polished Anti-surge Comp housing
Inclds -10 AN return fitting
Front Axles $600 OBO for the pair, will not break up the pair
Evo 8 axles
Driveshaft shop axle bar upgrade
New boots
Exhaust manifold $SOLD
Peak Boost Top Mount manifold
Flanged for T3 (undivided) and Tial 44mm
Inclds 4 bolt to Vband adapter and upper downpipe
Upper downpipe ends at bottom of block by oil pan
inlcds all related V-band clamps
Tial 44mm wastegate SOLD
Tial BOV, old style ---- SOLD
Fitting is for -4AN, inclds clamp
Driven Innovations Intake manifold----- SOLD
Flanged for 75MM TB. Manifold is raw uncoated
aluminum and has some gouges/scratches from
being moved in storage. Both the head flange and TB
flange are freshly machined to ensure perfect gasket sealing.
Boomba 75MM TB, Brand new, never installed --- SOLD
Inclds everything it would brand new
AMS Fuel rail SOLD
Inclds -6AN return fitting and -8AN feed fitting
Aeromotive FPR w/gauge $120 OBO
Golden eagle Vacuum manifold coated candy red $25
HKS 4" inlet air filter, brand new inlcds red extra filter $100
This is a GENUINE HKS product, not a $20 chinese special from ebay
AEM EMS V1--- SOLD
Inclds 3.5 bar MAP sensor, GM IAT and wiring pigtails
and laptop cable w/USB adapter
Evo 8 Dominick Iraggi 250 amp alternator $375 OBO
2500 miles on it
JDM Evo 7 valve cover, powder coated candy red $350
Powder coating is a 7 or 8 out of 10. It has normal wear
and a small crack (in the coating) near the rear PCV port.
The PCV is threaded for a -8 AN fitting and the side is
threaded for -8 AN fitting. Inclds Genuine HKS oil cap.
Stock Intake Manifold $250 OBO
Powder coated silver
Ported by Paradigm performance
See photos for minor oil stain on flange
and some road grime on the back side
Inclds STM EGR block off plate. The road grime
should come off with some goo gone or maybe
even a light wet sanding.
Stock TB with IAC and TPS sensor $175 OBO
[IMG]http://i3.photobucket.com/albums/y83/EvoInside/imag
e-43.jpg[/IMG]
Eagle Rods
King Race bearings
Cometic head gasket
GSC S2 cams
Fidanza cam gears
T-Case SOLD
10MM bolt upgrade
WaveTrac LSD
200 miles on it
Turbo ---- SOLD
Under 200 miles
Evo 8 axles
New boots
AMS Fuel rail SOLD
AEM EMS V1--- SOLD
2500 miles on it
e-43.jpg[/IMG]
Last edited by VTEC Killer; Jun 15, 2015 at 08:23 AM. Reason: Item sold, price reduced
All PM's returned. Anyone who is thinning about low balling me on the big dollar stuff like engine/tranny/tcase, don't waste my time or yours. Everyone knows what this stuff costs, it's no big secret.
