Rotating Assembly - TI rods, high-comp pistons, 100mm crank
I have for sale a full rotating assembly for a 4G64 block. The pistons are 87.5mm so they will NOT work in a 4G63 block. The kit includes a used 100mm 7-bolt 4G64 crankshaft, custom Crower Titanium H-beam connecting rods and custom Wiseco high-compression pistons. Of course final compression is going to depend on your headgasket thickness as well as combustion chamber volume, but this kit should be in the 12 to 13:1 range and were intended to run on methanol, ethanol or E85. I would NOT recommend trying to run pump gas at any boost level, but I'm not a tuner, so you can do whatever your tuner recommends.
These parts came out of an assembled, never fired, never ran short black that sat for quite a while. If I were going to use this kit I would re-polish the crank and a couple of the pistons. Brand new full set of rings straight from Wiseco is included.
$3000 shipped
Specs are as follows:
Crank:
- OEM Mitsubishi 4G64 100mm 2.4L crankshaft
- bearing surfaces should be polished.
Rods:
- Crower Titanium H-beam, P/N T93970B-HBEAM
- 406 grams with bolts
- 6.324 inch length (160.63mm)
Pistons:
- Wiseco 87.5mm, P/N CA-97515-7891
- CH 25.04mm
- dish = -7mm
- 299gm with top two rings
- DLC coated tool steel wrist pins, 90gm
$3000 shipped
Crank:
Rods:
Pistons:
- CH 25.04mm
- dish = -7mm
EVOlutionary
Oct 15, 2017 04:11 PM
EVOlutionary
Mar 3, 2017 01:00 PM
WTB[MidWest]: WTB: front and rear engine/trans mount brackets
EVOlutionary
Jul 3, 2016 09:09 AM
