SOLD!!!
Money is tight and my Evo needs repairs so these need to go.
I purchased these in December of 2008 from schiedes, who is a member on here. I never got around to installing them, so they have just been sitting in my closet since then.
These cams are in absolutely perfect condition, just as schiedes had told me prior to purchasing them. I believe he had them in for approximately 25k miles on the stock valvetrain with zero issues. All HKS cams are safe for use on stock valvetrain, as the ramp is not that aggressive.The only reason I never installed them was because i didnt have the extra money for injectors and a tune on the dyno. I wish i didnt have to sell them, but I have to replace my POS Fidanza flywheel that the ring gear detached from; so now i cant start my car. Sorry about the picture quality, i used my phone. I assure you these cams are flawless.
HKS 280
Advertised Duration - 280 deg
Effective Duration - 222 deg @ 1mm
Lift - 10.8mm Int / 10.2mm Exh
Lobe Centerlines - 110 deg Int / 110 deg Exh
LSA - 110 deg
Stock valve springs OK
compared to stock:
Factory EVO
Advertised Duration - 260 deg Int / 256 deg Exh
Effective Duration - ___ deg @ 1mm Int / ___ deg @1mm Exh
Lift - 10.0mm Int / 9.5mm Exh
Lobe Centerlines - 109 deg Int /111 deg Exh
LSA - 110 deg
Im asking $400.00 shipped. Thanks for looking
