For those looking into Pulley Kits
Old Feb 24, 2003, 12:18 PM
uranium9v's Avatar
So mirage pulleys will fit, but we'll need to find a new belt.....
Old Feb 24, 2003, 04:34 PM
pjal84's Avatar
That's the only problem I couldn't resolve. Plus, the language on the Unorthodox site doesn't lend itself one way or another whether the pulley is both lightened as well as made smaller. Yargh. If just lightened and made of alloy, stock ol' belt. If not, then there's a problem.
Old Feb 24, 2003, 06:06 PM
bahamut's Avatar
If using the 1.8L pulley from UR, you must change your 2 belts about 1 or 2 size smaller. I'll try to find the part # on the belts. Otherwise, it'll slip or fall off.
Old Feb 24, 2003, 06:11 PM
bahamut's Avatar
From miragetuner.net
"Here are the numbers from the sleeves of the belts that I fit on my 1.8L when I changed the pulley: 5050500 (5PK1270) & 5040290 (4PK0734). The brand is Dayco, Poly Cog. You can have them cross referenced. evolutionyz also added that these same belts will work with the TopSpeed UDP available through RevolutionsMotorsports."
Good luck!!!!
Old Feb 24, 2003, 08:29 PM
2wdSQL's Avatar
I have seen and held said pulley vs the stock pulley. It makes no difference unless you add a lightened flywheel.
Alchemist
Lancer Troubleshooting
Apr 22, 2013 11:54 AM
WORD
Dec 3, 2010 07:51 AM
the_cosworth
Lancer Engine Tech
56
Aug 9, 2007 09:16 PM
gldenchld
27
Apr 26, 2005 11:25 AM
i_love_spool
Lancer Engine Tech
16
Sep 3, 2003 06:01 PM
Quick Reply: For those looking into Pulley Kits
