DRL and DRL LED Strips
Old Aug 19, 2014, 09:25 PM
dxk
dxk's Avatar
not bad, looks like fog lights tho ;p
Old Aug 20, 2014, 02:08 AM
DP2k11's Avatar
Originally Posted by mikie209
more
looks good!care to share where you got these?
Old Aug 20, 2014, 11:51 AM
mikie209's Avatar
At jdmtoy, they were suppose to be fog light shrouds but didn't fit so I took them off and wrapped it in electrical tape to make it a bit thicker.
Old Aug 20, 2014, 04:52 PM
RA012124's Avatar
So while waiting for my replacement to arrive, I decided to try something else. Tell me what you think.
Would I be able to install something like that onto my empty ES fog light covers? I'm guessing holes would need to be cut out?
Old Aug 20, 2014, 05:24 PM
mRVRsport's Avatar
Location: Out towards the countryside of Dallas, TX (USA)
Actually, since those LED rings are smaller than the original Fog light openings, I'd imgine you Don't need to make any cuts. Just attach them directly to your fog-blanks. Makes for a very simple mod.
Old Aug 20, 2014, 07:23 PM
DP2k11's Avatar
Any links to the item?
Old Aug 21, 2014, 12:09 AM
mikie209's Avatar
http://store.ijdmtoy.com/Retrofit-Fo...s-p/aa1118.htm
The holes on the fog light housing are bigger than the LED. I wrapped the LED in electrical tape to make the circle bigger. Once I placed it I used hot glue to keep it in place. The wires on the LED is sealed with silicone and is water proof. You are able to take the LED out of the shroud it comes in also.
Old Aug 21, 2014, 07:17 PM
mikie209's Avatar
I was bored again today so I decided to try something different. I used the fog light housing that didn't work to see how this would look before i do this to my stock housings. I had some led emitters so I drilled some holes and stuck them in. The wholes are not aligned or equally spaced. I did this kind of quick.
Old Aug 23, 2014, 05:58 PM
Gatsby's Avatar
That's actually a good idea, how's it look when on? Also, what did you use to secure the led emitters in the holes?
Old Aug 25, 2014, 08:16 PM
mikie209's Avatar
I havent done anything lately on that. I would probably use glue gun or silcone. Those housings are a little different, still trying to figure out where i would place the emitters on the stock housing.
Old Oct 27, 2014, 10:57 PM
jostnyc's Avatar
i got these as well. finished installing. check out this thread.
https://www.evolutionm.net/forums/ou...these-out.html
Lightsaber
Feb 16, 2018 05:17 PM
tiesto14
Aug 9, 2016 05:20 PM
FMETTEE
Outlander Sport
Oct 17, 2015 07:54 PM
jayt27
Aug 14, 2015 06:08 AM
Watermelons
Outlander Sport
34
May 8, 2015 06:50 AM
Quick Reply: DRL and DRL LED Strips
