DRL and DRL LED Strips
Actually, since those LED rings are smaller than the original Fog light openings, I'd imgine you Don't need to make any cuts. Just attach them directly to your fog-blanks. Makes for a very simple mod.
http://store.ijdmtoy.com/Retrofit-Fo...s-p/aa1118.htm
The holes on the fog light housing are bigger than the LED. I wrapped the LED in electrical tape to make the circle bigger. Once I placed it I used hot glue to keep it in place. The wires on the LED is sealed with silicone and is water proof. You are able to take the LED out of the shroud it comes in also.
I was bored again today so I decided to try something different. I used the fog light housing that didn't work to see how this would look before i do this to my stock housings. I had some led emitters so I drilled some holes and stuck them in. The wholes are not aligned or equally spaced. I did this kind of quick.
I havent done anything lately on that. I would probably use glue gun or silcone. Those housings are a little different, still trying to figure out where i would place the emitters on the stock housing.
i got these as well. finished installing. check out this thread.
https://www.evolutionm.net/forums/ou...these-out.html
Lightsaber
Feb 16, 2018 05:17 PM
tiesto14
Aug 9, 2016 05:20 PM
Watermelons
Outlander Sport
34
May 8, 2015 06:50 AM
