Go Back   evolutionm.net > Miscellaneous > Other Cars
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 17, 2009, 11:36 AM   #1
Personal Sales Rating: (0)
2005 Mitsubishi Lancer Evolution
My Garage
stealthyevoviii's Avatar
Drives: 05 AS Evo VIII, 90 Nissan 300zx 2JZ-T
2JZ 300zx Problems
Okay first, I realize this is an Evo forum and I do have an Evo, but this problem may be applicable to all cars and not just engine specific. I have posted this in both the Supra and Nissan forums without any luck. Does anyone have any ideas on what could be wrong?
So I have a Nissan 300zx with a 1993 2JZ-GTE swap and am having some weird problems. The car is very hard to start, and only does successfully when the car is cold. It idles very low (~400-800 rpms) and cuts out when the throttle is released when driving. The car will only start about an hour later, when the engine temps seem to go down, even when jump starting it. It turns over but does not start initially, then when trying to start I just get the clicking noise without it turning over even once. The car currently has a small Braille racing battery which I believe has a shorted cell, but this isn't likely to be the issue as I have purchased a larger Supra battery from Autozone and tried to start the car with that, which resulted in the same problems. Also when jump starting the car, the jumper cables are extremely hot and the car seems to be pulling a ton of amps to start the car. The problems seem to get worse as the car warms up and gets hotter. Anyone have any ideas?
Modifications are listed here.
Thanks in advance
- Chris
__________________
05 Mitsubishi Evolution \////
CBRD Built & Tuned - BBK Powered
356awhp/346awtq on 93oct @ 25.5psi
90 Nissan 300ZX
MAMS Built & Tuned - 2JZ Powered
453rwhp/460rwtq on 93oct @ 16psi
Offline
Old Aug 17, 2009, 12:57 PM   #2
Personal Sales Rating: (2)
pwrofturbo's Avatar
Drives: 2000 Miata, Time Trial IX, 2G DSM
Send a message via AIM to pwrofturbo
Sounds like it could be a short. Check for continuity in all the charging circuitry.
__________________
-Zack
Quote:
Originally Posted by andyktlee View Post
he popped his collar so i popped him in the face
Quote:
Originally Posted by Durf View Post
If I was a man I would be so gay for you.
Quote:
Originally Posted by SASD209 View Post
Word, hella tyte and hella banned.
Quote:
Originally Posted by HobieKopek View Post
EvoM = Quizno's Toaster? We're all doomed. ...But deliciously toasty.
Offline
Old Aug 17, 2009, 01:05 PM   #3
whitedsm97's Avatar
Drives: blue by you evo VIII
alternator maybe.
__________________
bby evo.
Offline
Old Aug 17, 2009, 08:15 PM   #4
Drives: dsm
there HAS to be a better forum than here for JZ stuff or Z stuff, but basics would indicate shorts/grounds/alternator/battery/starter?
Tougher things to deal with would be the sensors/solenoids/electronic mumbo jumbo which is hard for us to decipher since this is frankenstein territory.
Did you go to a shop for the work? You can ask them?
Offline
Old Aug 18, 2009, 04:47 AM   #5
My Garage
Yeah thanks guys. Mid-Atlantic Motorsports did the swap in MD and we are taking it back to them, I just wanted to see what other people thought the cause might be. We were thinking that it might be a short or grounding issue. Thanks for the input guys
__________________
90 Nissan 300ZX
Offline
Old Aug 18, 2009, 05:18 AM   #6
Personal Sales Rating: (3)
gotrnet's Avatar
Drives: 2008 Lancer
had a similar issue with my eclipse. it was the starter in my case. it was shorting and draining the battery if i let it sit. It would take a lot of juice just to get it started. it was also having issues with idling. the new starter fixed that as well. i think it was just pulling too much power and when the car was at idle it would die. just an option.
__________________
2008 lancer
Offline
Old Aug 18, 2009, 09:18 AM   #7
My Garage
^ I will definitely look into that. Thanks
__________________
90 Nissan 300ZX
Offline
Old Aug 18, 2009, 09:31 AM   #8
evillancer06's Avatar
Drives: EVIL IX
that looks like a nice setup. anymore pictures on it?
Offline
Old Aug 18, 2009, 09:33 AM   #9
Drives: EVIL IX
sorry found them. car looks pretty nice.
Offline
Old Aug 18, 2009, 09:36 AM   #10
ev0lution9's Avatar
Drives: '06 Evo 9
its ounds like your alternator. good luck!
__________________
335 whp 345 wtq @ 24psi
IVEY TUNED
Offline
Old Aug 18, 2009, 11:02 AM   #11
My Garage
Quote:
Thanks, now if it would only run....
__________________
90 Nissan 300ZX
Offline
Tags
2jz, 300zx, 90, evo, hard, idle, located, makes, noise, powered, problems, start, starter, starting, weird
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
