Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
ok to drive with bad transfer case?
Old Jan 2, 2007, 12:56 PM
hang187's Avatar
i just got back from a local auto shop to check wierd noises from the front, and he said i have a blown or bad transfer case. i'm leaving to northern california on thursday and dont have time for the dealer to replace it. just wanted to know if its ok to drive there and back. any thought is great. oh i also saw the mechanic put some other fluid in when he looked at it, i no its not diaqueen or anything like that is it ok also.
hang187 is offline
Old Jan 2, 2007, 01:31 PM
Evogelion's Avatar
NO don't do it.. I had problems with the transfer case in the past, it will eventually lock up your car, mine did that to me on the freeway in Kentucky..
if you ignore it you risk having to replace the driveshaft as well..
Evogelion is offline
Old Jan 2, 2007, 01:34 PM
bvdawg13's Avatar
ya get that fixed ASAP or your gonna end up screwed on the bak of a tow truck
bvdawg13 is offline
Old Jan 2, 2007, 01:36 PM
Smike's Avatar
Location: somewhere testing various tires, brakes, and suspensions.
And he didnt put the right fluid in it?
Flat-bed home. Change the fluid back to OEM. Have it checked by a mech. that knows Evo TCs.
Smike is offline
Old Jan 2, 2007, 01:44 PM
Evogelion's Avatar
I would just take it to the dealer to check it out if you're not sure.
Old Jan 2, 2007, 01:52 PM
hang187's Avatar
did you also have like a whining noise from the front? if so my, car is running fine but it could lock up on the freeway? i'll get it check at the dearlership. thanks
hang187 is offline
Old Jan 2, 2007, 01:53 PM
Evoryder's Avatar
many people rock the bad TC ...in time it will lock up...just go easy on the car and obviously don't launch it
Evoryder is offline
Old Jan 2, 2007, 02:02 PM
Evogelion's Avatar
Ya I had the whining noise, if you're not under warrenty, it can cost up to a couple thousand to fix..
Old Jan 2, 2007, 02:06 PM
ashumo's Avatar
Yeah if you can't get warranty coverage I would get it fixed before it amounts to being to much money.
Rent a car to drive to Nor Cal. Leave your Evo to get fixed.
ashumo is offline
Old Jan 2, 2007, 02:09 PM
TxEvo8's Avatar
Do Not Drive It!!!
TxEvo8 is offline
Old Jan 2, 2007, 02:48 PM
hang187's Avatar
the mechanic also put some exxon fluid into the differential and transfer case. as long as the classification grade is the same as oem, it should be fine?
hang187 is offline
Old Jan 2, 2007, 07:17 PM
jd323's Avatar
oh dear God. Get that car parked immediately.
jd323 is offline
Old Jan 2, 2007, 07:37 PM
Ultimate CC's Avatar
Ill be needing a TC soon...
Ultimate CC is offline
Old Jan 3, 2007, 11:30 AM
GTisRule's Avatar
Fluids have to be what Mitsubishi recommends to avoid warrantee problems. I don't know about gearboxes, but it specifically says in the owner's manual that you must use Mobil 1 full synthetic for the engine, I'd imagine they're strict on the drivetrain too.
GTisRule is offline
Old Jan 3, 2007, 12:09 PM
Autoxevo's Avatar
I wouldnt drive it, high speed (80ish) and mountain passes will put a strain on it. If you do drive it get a AAA membership (RV+) that way they'll tow you 250 miles for free.
Autoxevo is offline
Quick Reply: ok to drive with bad transfer case?
