Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
ok to drive with bad transfer case?
Old Jan 3, 2007, 12:21 PM
rcheung's Avatar
Originally Posted by hang187
did you also have like a whining noise from the front? if so my, car is running fine but it could lock up on the freeway? i'll get it check at the dearlership. thanks
Can you get a soundclip of the noise?
rcheung is offline
Old Jan 3, 2007, 12:25 PM
Ev0ikon's Avatar
the mechanic also put some exxon fluid into the differential and transfer case. as long as the classification grade is the same as oem, it should be fine?
NO!
Don't ever let this happen again. Bring the car to the dealer and have the correct fluid in there after flushing it out good.
Keep a record if this as evidence in case your drivetrain blow up. I would not drive it again until this is done.
Ev0ikon is offline
Old Jan 18, 2007, 02:16 AM
lilraysEvo's Avatar
i rocked a bad tc for like 10000 miles then i put a tre tc in it lol
lilraysEvo is offline
Old Jan 18, 2007, 09:58 AM
Evogelion's Avatar
Anyway let this thread die plz
Evogelion is offline
umarkhan102
Mitsubishi TC-SST Discussion
Apr 18, 2017 04:48 PM
rogerlam
Jul 5, 2016 09:19 AM
Bosshog
Apr 6, 2006 11:09 AM
soundfx007
16
Dec 17, 2004 11:30 PM
Rez90
Oct 16, 2004 09:03 PM
Quick Reply: ok to drive with bad transfer case?
