How to bolt in harnesses?
Once installed let us know how you like the Takata drift III. I been debating if I want those or the standard Race 4pt. What made u choose the drift? If u don't mind me asking thanks. Gl with the install...
Cool thanks for the info. I was also debating the snap vs bolt versions. I think you just helped me decide which ones I'd like. Nice choice and logic behind it. Thanks again!
Aren't you supposed to remove the original bolts and replace them with "eye bolts" or add their snap on kit, Or did u already try that?
http://www.takataracing.com/products/eye-bolts
http://www.takataracing.com/products...le-snap-on-kit
The second one for the bendable snap bracket is just for when you put the harness in a hard to reach or tight fitting location Which I may have to do :/ haha
Normally, harnesses are either attached in stock locations (due to their tested strength and durability) or new ones are created (welded in usually).
With my Schroth harness, I used the snap-on clips for the shoulder attachment to the Buschur bar and the bolt-in buckles to mount to the stock seat belt locations. I'm not sure how to do it with snap-in clips that are sewn into the harness. Follow golgo13's suggestion and take it to a race shop.
Most likely you will end up having to use the snap on kit from Takata.
I used all eye bolts and clips for sub and waist belts. I put them in the location (or as close as possible) advised by the manufacturer's installation instructions with a stainless steel 3"x2" backing plate using Grade 8 hardware, spring washer and loctite.
The shoulder harness is wrapped around the harness bar on the roll bar.
