Oct 20, 2009, 12:36 PM
Personal Sales Rating: ( 12)
Drives: EVO VIII
Which Rear Wing: 60" or 67" wide ??
As I develop my track car for road racing, gain more power
and more grip, I'm seeing I'm lacking in rear downforce and
the stock oem rear wing is beginning to feel inadequate.
I'm considering an aftermarket carbon fiber rear wing.
Since many of you already have these on your cars,
I was wondering which are the better performing rear wings?
Is the 60" or 67" width better and why?
Is there a recommended riser height?
Thanks
__________________
Evo 8 . . .
Offline
Oct 20, 2009, 12:45 PM
Personal Sales Rating: ( 0)
Drives: '08 RR EVO MR
get a apr gtc-300 or something similar. you want it mounted right along the roofline, but it all depends on your sanctioning body's rules for building the car.
Offline
Oct 20, 2009, 12:49 PM
Drives: EVO VIII
I'm told the larger wings will actually create more drag on the straights.
Is there a wing width size trade-off?
__________________
Evo 8 . . .
Offline
Oct 20, 2009, 01:11 PM
Personal Sales Rating: ( 3)
Drives: 2006 IX SE
The bigger wing can make more down force but drag goes up with the square of the downforce. Increasing wing span mitigates this somewhat, but generally more downforce=more drag.
But for a given amount of wing down force, a larger span wing will generally make less drag. But it will weigh more, so there's another trade.
Offline
Oct 20, 2009, 01:57 PM
Drives: EVO VIII
Interesting.
So what is the "ideal" wing span for an Evo for road racing ??
Inotherwords, what are you guys using?
__________________
Evo 8 . . .
Offline
Oct 20, 2009, 02:07 PM
Drives: Evo 8
mike@Kognition has a airfoil that he bought off a Formula one team, he then adapted it to to our humble little track cars.
It is actually the wing that JC Meynet is running.
- other rules that apply... the closer to the roofline the better (actually with a single element you want .70-1.0 of the cord length, a non-stalled diffuser, and that will give you the best downforce.)
-mounting points to the chassis are substantially better then the trunklid.
__________________
{GSC}{enkei}{swift}{ferodo}{20psiMR}{ROBIspec///}{KW}
Eddie says:
it is fun to passenge with you
Brandon says:
well trust me I just turned the log ride into the tower of terror....
Eddie says:
lmfao
Offline
Oct 20, 2009, 02:20 PM
Personal Sales Rating: ( 48)
2003 Mitsubishi Lancer Evolution
Drives: 03 EVO VIII White
It really depends on how much force you can create up front. You need to be able to balance the rear wing - otherwise you push down the back at the cost of raising the front.
__________________
jid2 Built: Now featuring E85 super fuel
2.3L - GT3076R .63A/R, ETS equal length, Kelford 272's, BC valve springs, 1mm O/S valves, FIC BM 1450's, Full-Blown dual Walbros, Buschur IC, jid2 intake, airbox, IC pipes, APS BOV, TBE, ACT HDSS, Stock ECU, 28 psi 466hp/420 ft-lb...
Build Thread
Binary Lowered Recaro Seats, Girodisc 2-Piece, brake ducting, ST43's, SS lines and ATE Superblue, KW V3's 8K/10K, jid2 flat-bottom, adjustable splitter and aero, 18x9.5 +40 NT03's 265/18/35 BFG R1's
Offline
Oct 20, 2009, 03:50 PM
Drives: EVO VIII
My front has an APR carbon fiber front splitter.
__________________
Evo 8 . . .
Offline
Oct 21, 2009, 08:25 AM
Drives: EVO VIII
Anybody wanna go out on a limb with a recommended wing span for me?
__________________
Evo 8 . . .
Offline
Oct 21, 2009, 08:35 AM
Silver Sponsor
Personal Sales Rating: ( 40)
2003 Mitsubishi Lancer Evolution My Garage
Drives: '04 evo8 daily driver, '03 evo8 time attack car, 08 outlander
i beleive the 67 requires widebody fenders? correct me if i'm wrong. and the wings are never allowed to be outside the width of the car.
Offline
Oct 21, 2009, 09:30 AM
I'd go with the Aeromotions R2 Static. Cool company, made in the USA, adjustable. They have an EVO model. Roughly $1700.
http://aeromotions.com/products/r-series/
__________________
Build Thread
Offline
Oct 21, 2009, 01:29 PM
Drives: Evo 8
I would also mount that splitter to the chassis
__________________
Eddie says:
Brandon says:
Eddie says:
lmfao
Offline
Oct 21, 2009, 01:32 PM
Drives: EVO VIII
I'm thinking to get the APR GTC300 61" wing.
How would you mount the wing to the chasiss?
Would the same oem mounting holes be used
and just extra supports underneath?
__________________
Evo 8 . . .
Offline
Oct 28, 2009, 04:03 PM
I've been emailing the guys at Aeromotions, their EVO VIII fixed wing is 65" wide with a 10.2" cord, mounts can be 10" or 12" tall. This is what I would do.
__________________
Build Thread
Offline
Tags
aftermarket, building, carbon, drag, evo, evolutionm, fiber, kognition, location, mount, race, racing, rear, road, wing, wings  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
