Oct 8, 2009, 12:37 PM
Personal Sales Rating: ( 12)
Drives: EVO VIII
Anyone Running 285/18 Tires on Evo 8 ??
Hi,
I'm running BFG R1 tires, 265/35/18's on 18x9.5 @ 27mm offset,
Enkei NT03+M wheels, on my Evo 8 for track use.
My fenders are rolled and I can't seem to fit anything larger.
My camber is set at -3.0F / -2.0R.
I know I've heard guys running 285 Hoosiers.
How can I do this without putting on a wide fender kit?
Will a different offset wheel help?
Will 10" wheels fit?
...lots of questions...
Thanks.
__________________
Evo 8 . . .
Offline
Oct 8, 2009, 01:03 PM
Personal Sales Rating: ( 31)
Drives: 03 Apex Silver Evo VIII - 05 WRB/Gold STi (both gone) - 06 EB Evo IX
I haven't done it, but I know a member that ran 285 Hoosier R6's on a 18x9.5" rim. Not sure what the offset was but he didn't have any time of widebody kit or anything. It was an Evo VIII.
Offline
Oct 8, 2009, 02:02 PM
Drives: EVO VIII
Quote:
I'd love to find out how he did it.
__________________
Evo 8 . . .
Offline
Oct 8, 2009, 02:53 PM
Personal Sales Rating: ( 1)
there's nothing different between an evo 8 and 9 in terms of fitting tires. you have the wrong offset wheels for the rear. with a 9.5 et 35 wheel we barely fit and you're a full 1/4" further out at least.
Offline
Oct 8, 2009, 02:58 PM
Drives: EVO VIII
Quote:
Perhaps a 35 offset would fit better, but the 27's do fit.
Regardless, I'd like to sell the two sets of wheels that I have now anyway,
and get either a different offset wheel or go to the wider 10" rim.
Edit:
__________________
Evo 8 . . .
Offline
Oct 8, 2009, 03:11 PM
Personal Sales Rating: ( 48)
2003 Mitsubishi Lancer Evolution
Drives: 03 EVO VIII White
I run the same 265 BFG's on a +40 NT03, they are tight. I get a touch of rub in the rear on the control arm. Up front is a friggen' mess. I have trimmed the fenders and liners, I relocated the front liners more inward, I also cutout all the fender liner mounts at the lip of the fender. I have positioned the fenders as far out as possible given the stock mounting holes, and used spacers under the front mounting point. I still get rub right on the inside edge of the fender lip and various areas in the wheel well. I'm going to slot the mounting holes and get the fenders spaced out about .25" more.
That said I have seen EVO's running my same wheel on 285 hoosiers - but I don't know what it took. I think they ran a lot of camber!
__________________
jid2 Built: Now featuring E85 super fuel
2.3L - GT3076R .63A/R, ETS equal length, Kelford 272's, BC valve springs, 1mm O/S valves, FIC BM 1450's, Full-Blown dual Walbros, Buschur IC, jid2 intake, airbox, IC pipes, APS BOV, TBE, ACT HDSS, Stock ECU, 28 psi 466hp/420 ft-lb...
Build Thread
Binary Lowered Recaro Seats, Girodisc 2-Piece, brake ducting, ST43's, SS lines and ATE Superblue, KW V3's 8K/10K, jid2 flat-bottom, adjustable splitter and aero, 18x9.5 +40 NT03's 265/18/35 BFG R1's
Offline
Oct 8, 2009, 03:55 PM
Personal Sales Rating: ( 4)
Drives: 2006 EVO IX MR
I'm on Enkei RPF1 18 X 9.5 with a 38mm offset all around. In the front I have 20mm spacers with ARP wheel studs. The tire I’m running is a 275/35/18 Azenis. They currently rub the wheel fenders in the front. I do think a 285 would fit in the rear but you may have serious rubbing issue in the front.. Just a FYI
__________________
Mike
AEM EMS Tuner
All Tuned by me.
-Evo IX GT30R Powered!! (10.9 @ 122) Full weight and Stock motor at 30psi
-98GSX 42R Powered!! (10.1 @ 146)
Offline
Oct 8, 2009, 04:14 PM
Drives: '03 Lancer Evolution 8
I've got 285/30/18 Yokohama AD08s on Enkei NT03-M 18x9½+40 offset. I had to do tons of fender work, but it does not rub one bit!
__________________
CarDomain pics
Mods: GSC S1 cams, QTP 3" electric cutout downpipe, Hallman Pro MBC @22psi, Walbro 255 fuel pump, Vibrant cone air filter, Nisei LICP, custom self-tune, RobiSpec KW Club Sports, 18x9½+40 Enkei NTO3-M, 285/30/18 Yokohama Neova AD08
Offline
Oct 8, 2009, 04:19 PM
Drives: EVO VIII
Quote:
Thoe99 -
Is that an aftermarket wide fender kit?
Which one is it and how many "mm" wider is it?
__________________
Evo 8 . . .
Offline
Oct 8, 2009, 04:36 PM
It's Dave's fender mod kit. He sells them on this board. Cheap, effective, and reversible solution, instead of spending thousands on a new fender and paint job. It expanded my fenders at least .75". There are different settings on the kit for you to choose.
__________________
CarDomain pics
Offline
Oct 8, 2009, 04:57 PM
What Thoe99 did is similar to what I've been doing, although I'm focusing on moving the fender at the top mounting points more than simply deforming the fender in the middle.
Another point is that "not rubbing" is a very relative statement. My car doesn't have rubbing issues on the street, or 90% of the corners at the track. It depends on how much body roll you get. It takes 1.23 G's to make mine rub on my suspension setup. Most yahoos would say my tires fit awesome - but that's because they don't really get the suspension moving
__________________
Build Thread
Offline
Oct 8, 2009, 05:11 PM
Drives: EVO VIII
What is the principle behind Dave's kit... bending out the front fender and re-setting it out more?
How does Dave do the rears?
__________________
Evo 8 . . .
Offline
Oct 8, 2009, 05:19 PM
True, I haven't run into any rubbing issues on the streets yet, but will stress test this at the road course this weekend. Before completely fixing all my rubbing issues, my skirt was the only area that would rub both on the streets and at the tracks. I've improved that issue so that it doesn't rub at all on the streets now, so we'll see.
Where does yours rub when it's stressed?
__________________
CarDomain pics
Offline
Oct 8, 2009, 05:29 PM
It expands the fender out based on the bolting points of the fenders, using spacers and tabs. The kit doesn't do anything for the rears.
__________________
CarDomain pics
Offline
Oct 8, 2009, 06:40 PM
Drives: EVO VIII
So, if someone wanted to do the fronts and the rears...
Who has the rear wide fender kit of choice ??
__________________
Evo 8 . . .
Offline
Tags
285, evo, fitting, make, tire, tires, tyres, viii, wheel, wheels, wide, widest, wite  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
