Oct 9, 2009, 11:13 AM
Personal Sales Rating: ( 4)
Drives: 2006 EVO IX MR
BTW. I have stock fenders with 2.5 degrees of camber in the front and they tuck fine. They just rub the wheel wells a little bit and side skirts.
__________________
Mike
AEM EMS Tuner
All Tuned by me.
-Evo IX GT30R Powered!! (10.9 @ 122) Full weight and Stock motor at 30psi
-98GSX 42R Powered!! (10.1 @ 146)
Offline
Oct 9, 2009, 11:29 AM
Personal Sales Rating: ( 12)
Drives: '06 Evo 9 MR, '95 4Runner
Quote:
Originally Posted by george3
So, if someone wanted to do the fronts and the rears...
Who has the rear wide fender kit of choice ??
Cheapest/easiest way to pursue the rears is cutting or rolling the inside lip off, run a 38-40 offset wheel and see if the 285s fit... the fender can also be pulled outward if rolling isnt enough... I would have a body shop quote you on it and perform it... search for posts on here by a member named Warrtalon, back in the day he used to post a lot and IIRC he ran 285's, tracked his car a lot-
Offline
Oct 9, 2009, 01:05 PM
Personal Sales Rating: ( 1)
Perhaps a 35 offset would fit better, but the 27's do fit.
sorry, I thought the question was how to fit 285's in the rear.
Offline
Oct 9, 2009, 01:23 PM
Personal Sales Rating: ( 48)
2003 Mitsubishi Lancer Evolution
Drives: 03 EVO VIII White
The +40 NT03's will help keep the 285's away from the rear fender lips at the cost of the control arms maybe seeing a little rubbing.
__________________
jid2 Built: Now featuring E85 super fuel
2.3L - GT3076R .63A/R, ETS equal length, Kelford 272's, BC valve springs, 1mm O/S valves, FIC BM 1450's, Full-Blown dual Walbros, Buschur IC, jid2 intake, airbox, IC pipes, APS BOV, TBE, ACT HDSS, Stock ECU, 28 psi 466hp/420 ft-lb...
Build Thread
Binary Lowered Recaro Seats, Girodisc 2-Piece, brake ducting, ST43's, SS lines and ATE Superblue, KW V3's 8K/10K, jid2 flat-bottom, adjustable splitter and aero, 18x9.5 +40 NT03's 265/18/35 BFG R1's
Offline
Oct 10, 2009, 09:26 AM
Personal Sales Rating: ( 0)
Drives: 2003 Evolution
A good body man can make you wide body quarter panels from metal. Look at what hot rod custom shop's do on old Fords. Probably cost less than buying a wide body kit and really making it look sweet. Just ask anyone who buys Siebon doors and then finds out it will cost $5000 to install and make them look like new stock doors.
Offline
Oct 10, 2009, 07:43 PM
Drives: Evo 8
I have 285 V710s(yes I know they run smaller then the hoosiers) on 35 offset wheel. I also have quite a bit of clearance..They are my AX wheels so I would know if I had any rubbing.
I have pulled the rears and also relocated the back bumper bolt.
you can somewhat see the clearance...
__________________
{GSC}{enkei}{swift}{ferodo}{20psiMR}{ROBIspec///}{KW}
Eddie says:
it is fun to passenge with you
Brandon says:
well trust me I just turned the log ride into the tower of terror....
Eddie says:
lmfao
Offline
Tags
285, evo, fitting, make, tire, tires, tyres, viii, wheel, wheels, wide, widest, wite  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
