HUGE congratulations to one of our California dealers, James Reese of Reese Tuning for just taking the Redline Time Attack Street Class National Championship with his 2005 EVO RS.
The Redline Time Attack basic rules for street class are:
Must retain all factory glass, full interior in the front area ( front seats, dash, center console,heater core,door cards, carpet.) Rear seats may be removed.
Must have a cat in the exhaust system and must be completely under the body of the car.
255 max width on the street awd class. With a treadwear of a minimum of 140. Can't run leaded fuels. Car must retain factory body panels. Carbon hoods and trunks are permitted.
Since James has opened his shop he has used mostly Buschur Racing parts in the build of his EVO. It's been a long road with quite a few changes to get the car to it's current National Championship status. He started out with a stock block FS635 and bent a stock rod. We then built him a Stage 3 2 liter shortblock. After running the FS635 for a bit longer James decided he wanted to step up the the HTA82. The combination of the HTA82 along with the BR 2 liter made 689hp on Reese Tuning MD500 AWD dyno.
The EVO is still street driven when it isn't on the track winning races. James says, "The car wouldn't be what it is today without the ****en BR2.0L. The help of jarrod and nick. The BR parts. Most of all your cranky ass!! I will continue to use your parts as long as the car is in my garage."
This entire season was run on the same 2 liter with zero technical problems and carried the car through the last race which clinched the championship.
Also a big congratulations to the driver, JEREMY TOYE, without him the championship would not have possible.
The complete build and parts list of the car is as follows:
TUNED, BUILT AND OWNED BY JAMES REESE
689 WHP 545TQ ON THE MD500 EURO
POWERD BY BUSCHUR 2.0 BLOCK
BUSCHUR FUEL RAIL
BUSCHUR FRONT MOUNT INTERCOOLER KIT
BUSCHUR UPPER & LOWER IC PIPE KIT
BUSCHUR 4" INTAKE PIPE
BUSCHUR RACING DOUBLE PUMPER FUEL KIT
BUSCHUR TURBO BACK EXHAUST W/ BULLET MUFFLER
BUSCHUR COIL ON PLUG CDI BOX
BUSCHUR CAM ANGLE SENSOR HEAT SHEILD
BUSCHUR HTA 82 TURBO KIT
SUPERTECH DUAL VALVE SPRING KIT
JACKSON AUTO MACHINE BIG BORE LIFTERS
M1 L19 HEADSTUD KIT
MIL SPEC 100 CELL HIGH FLOW CAT
MIL SPEC 65MM THROTLE BODY
EXEDY TWIN CARBON CLUTCH
KELFORD 272 CAMS
REESE TUNING VERSION 2 INTAKE MANIFOLD
AEM EMS 5 BAR MAP SENSOR
AEM UEGO
PRECISION 1200CC INJECTORS
CBRD 2" RADIATOR KIT
BEATRUSH MOTOR MOUNT KIT
**SUSPENSION**
SPONSORED BY ROBISPEC
ROBI SPEC KW 2 WAY RACE SHOCK
ROBI SPEC 26MM REAR SWAY BAR
CUSCO FRONT CAMBER PLATES
WHITE LINE COMPLETE SUSPENSION BUSHING KIT
WHITE LINE BUMP STEAR KIT
WHITE LINE CENTER ROLL KIT3
Here are a few pictures of the car:
