Go Back   evolutionm.net > Competition > Motor Sports
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 8, 2009, 03:10 PM   #1
Personal Sales Rating: (0)
2008 Mitsubishi Lancer Evolution
Nsomniac's Avatar
Drives: EVO X, 4runner V8 Sport, 95 EB Bronco full size
Most bang for my buck STU
Current car: Stock Evo X on star specs. I have an accessport, but believe it's not legal so I reprogram it to stock prior to events. I also have the car aligned to -1 degree camber in the front and back. I know I can increase that more, but need to find a better shop that knows what they are doing first.
Anyways - I'm finishing in the top 5 most events (PAX) and 1st in my class, and I am consistently within .1-.3 seconds of the top spot. Two of those drivers are top 20 drivers from nationals last year, and have a ton of experience on me, so I feel like my driving is pretty solid for a 3rd year driver.
Our bonuses and things got cut this year, so a new suspension was out of the question. That being said, would it be worth it for me to get a new front/rear sway bar kit if I'm keeping the stock suspension until next year? Is that going to give me any advantage this year, maybe allowing me to catch the leaders if my driving continues to improve like it has?
Also, if there are any other ideas, please toss them out there. I'm pretty set on staying in STU right now because I can't go with a second set of rims/tires for R-comps, and A-stock vs. S2000's isn't very fun. Also, if someone can give me a more definitive answer about the ability to use the AP maps in STU, I would appreciate it.
Thanks!
__________________
Quote:
Originally Posted by Danny Boy View Post
I will fire a proton torpedo right up your exhaust port.
(Never realized just how gay that sounds until now)
Quote:
Originally Posted by ambystom01 View Post
If we were meant to eat only vegetables, why do we have canines, incisors, a small appendix, a highly acidic stomach, forward facing eyes and a fast metabolism?
Offline
Old Jul 8, 2009, 03:25 PM   #2
drewgray's Avatar
Drives: Evo
You can use AP maps as long as no value regarding boost is touched.
__________________
08 GG Evo X
89 Mirage Turbo
Offline
Old Jul 8, 2009, 03:26 PM   #3
Personal Sales Rating: (2)
Drives: '06 Evo SE
Concerning the AP: the only maps legal in STU are 1) stock and 2) one that doesn't change boost. If you're running a Stage 1 or 2 map, it's illegal. There is likely some power left in the car if you just tune it without changing boost, but IMO, until you have the suspension sorted, it's a waste of time. If you aren't happy with how the car handles, you can't really use the extra power.
As far as bang for the buck mods, rear sway bar and alignment for sure. Set bar to full stiff. If you can flip the front camber bolts like the Evo 8/9 then you can get a decent amount of camber up front. Run as much camber as possible in the front and a slight bit of toe out up front (or 0 if it's a daily), and go to town.
After that, you're really just a set of good coilovers away from having a pretty competitive car.
Offline
Old Jul 8, 2009, 04:39 PM   #4
NTEC Club Forum Leader
Personal Sales Rating: (4)
goofygrin's Avatar
Drives: RR EvoX
Where are you at? A stock Evo X here wouldn't really be competitive at all in STU.
Your AP is legal -- just the maps that are provided are not. You can use ATR to make changes/log a tune that only changes timing, fueling, and MIVEC (no boost). You'll need a wideband though.
My recommendations for low buck mods?
- brake pads
- $25 camber bolts. You flip the top bolt like on the VIII/IX to make the paint dot away from the strut (~-2* camber). Then you put the eccentric bolt in the bottom and you should be able to get to about -3*). (http://www.clubrsx.com/cr/SPC-81260.html)
After that... it's a tossup. Two schools of thought, springs/sways, coilovers/sways. The front sway did more for me than the rear sway, but it was 4000x harder to install.
Other things you can do and stay legal in STU:
- intake
- exhaust (full turbo back, but you have to keep a cat)
- stainless brake lines
You should also consider a CG Lock or a harness to help keep you in the car.
__________________
Are you in the North Texas area? Check out NTEC!
Denver says I'm a hypocrite and I don't deny it.
Online
Old Jul 8, 2009, 08:23 PM   #5
WAM
WAM's Avatar
You really ought to do your own alignment. Front camber is pretty important and you don't really have to adjust it...you only get to choose between the two settings. (Not counting Goofy's extra cam bolt) But then you have to reset your toe and that can be done with just a 7/8 open wrench to loosen the jam nut and a 13mm to rotate the tie-rod. By turning the steering wheel, you can do it without even jacking the car. But mark the tie rod with tape or something and keep track of it. On my X one turn each side changes it from 1/8" in to 1/4" out. My camber came out 2.6 and 2.8 degrees with just the top bolt repositioned. Go the longacre site and check out their toe measurement system. It's pretty cheap, but once you see how they do it you can duplicate it for practically nothing. (two aluminum plates and two tape measures.)
I submitted this to the alignment sticky (msg #21):
Stock Wheel and Alignment Specifications
If you want to try something cheap, but 'out there', drill your shock tubes, drain but capture the fluid, and replace that same amount with a high viscosity shock fluid from a motorcycle shop. Then cover with a rubber patch and secure it with a radiator hose clamp. Don't know for sure if you can do this on the Evo struts, but I've done it on other cars. And you WERE going to upgrade the shocks next year anyway, right?
Goofy, I keep hearing about how hard it is to change out the front SB. I know you have to take off at least one wheel, but what all makes it so hard? Is there an install thread you can point me to?
__________________
'08 Evo X MR, silver
Offline
Old Jul 8, 2009, 09:47 PM   #6
goofygrin's Avatar
Drives: RR EvoX
you have to take the front subframe off
ETA: if you got 2.8* of camber with the stock suspension and bolts, then you need to find a different alignment tech... because it ain't happening unless they fudge the computer.
You have an iphone? Get the level app and verify it.
__________________
Online
Old Jul 8, 2009, 11:35 PM   #7
WAM
WAM's Avatar
Measuring over a 22" vertical reference, the top of the tire leans in 1.07". Maybe I did the math wrong, (show me) but my calculator says that's 2.8 degrees.
1.07/22 = .0486
arc tan .0486 = 2.78 degrees
Don't need no iphone...gotta a watkins pro digital camber gauge. But I've changed the ride height an inch since those measurements, so it would be a little bit apples and oranges. My coilover supplier is sending me some new pieces, so I'll double check everything again when it comes off my lift. BTW, I just ordered your cambolts...thanx for the tip.
__________________
Offline
Old Jul 9, 2009, 07:44 AM   #8
sQuid^'s Avatar
Hey goofy, did you install those eccentric bolts on your evo x?
That seems like a great way to get more camber!
Offline
Old Jul 9, 2009, 08:27 AM   #9
goofygrin's Avatar
Drives: RR EvoX
Quote:
1.07/22 = .0486
I'm just saying, _most_ people are getting 1.8-2.0 with just the top bolt flipped. If you're getting an extra degree, then either your car has something bent, was built sloppily or is a freak. All of which are valid options .
I did, but then I removed them when I got new brackets on my coilovers... so now I'm up to > -4.5* of camber.
Evo_Someday has them in his VIII and he's getting ~3*
__________________
Online
Old Jul 9, 2009, 08:57 AM   #10
WAM
WAM's Avatar
Yeah, I understand your point. The car has been rallycrossed a couple times so damage isn't out of the question. But I've since pulled those struts, installing coilovers. The original struts look perfect to me. Dunno.
I do bias the suspension towards maximum camber with a bottle jack prior to tightening the bolts, top & bottom. Maybe a lot of people skip that step?
__________________
Offline
Old Jul 9, 2009, 09:09 AM   #11
goofygrin's Avatar
Drives: RR EvoX
I've heard of people using a tow strap
I can't imagine that setting the camber that way
a) sticks
b) doesn't damage anything
But... I didn't even sleep at a Holiday Inn last night! :P
__________________
Online
Old Jul 9, 2009, 09:44 AM   #12
drewgray's Avatar
Drives: Evo
I was able to get ~ -2.5* out of the stock bolts, and can get -4* out of just camber bolts up front. eh...
__________________
08 GG Evo X
89 Mirage Turbo
Offline
Old Jul 9, 2009, 01:54 PM   #13
WAM
WAM's Avatar
a) sticks
I'm not putting a lot of force on anything with the jack. Just taking out all the slop in the maximum camber direction before tightening the bolts. If you tighten the bolts with the suspension hanging all the slop in the system goes the other way.
A better way would be to mount the wheels & tires and settle the car to ride height before tightening any suspension bolts. You could do it with blocks under the tires, but seems a lot of work.
__________________
Offline
Tags
81260, bolt, camber, eccentric, ends, evo, facing, flip, install, jam, measurement, nut, rod, spc, strut, tie, ton
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
